Question about Protron PLTV-37 37 in. LCD Television
There is no picture and the red power light does not turn on
  • 3 more comments
  • mingling215 Feb 06, 2010
    WHAT DO YOU MEAN REPLACE WITH SAME RATING
    WHAT DO YPU MEAN REPLACE WITH SAME RATING
    WOULD THE SAME WORK FOR PROTON PLTV 3250
    WOULD THE SAME WORK FOR PROTRON PLTV 3250
    I DIDN'T TAKE THE BACK OFF YET, OR REPLACE FUSE. AS SOON AS I DO IT AND IT WORKS WILL CONTACT YOU. THANK YOU FOR NOW
  • 10,594 Answers
Make sure AC power cord is properly plugged in TV and wall socket.
If still no power sign in tv that means power supply is defective, if you are handy with electronics stuff then take off back cover of tv and check fuse in power supply board, replace it with same rating if found blew off.
If fuse blow again then power supply board will be replace.
Let me know if tv is different model other than Protron PLTV-37
Thanks.
Posted on Feb 06, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Feb 06, 2010
    Fuse would have some rating written on it like 5A 120V or 6A 240V like that, get same fuse from Radio Shake or any other store and put that fuse in TV.
    I just explained it.
    Fuse has some specifications or limited current can flow through it and if exceeded it will blow up and disconnect the circuit to protect it from fire or smoke etc.
    If you take out old fuse from power circuit board, you will see some digits written on it, get similar fuse from nearest store. Sale person will help you to get similar fuse.
    Yes, same fuse would be in PLTV-3250
    Yes sir, I just replied your question and email notification would be on its way
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
No picture no sound, red light on, left unplugged over-nite, no change. Turn on/off a number of times, got back perfect picture/sound. Turn off, same problem, no picture/sound, red light on. Tried...
First if the model number is right here: When the red light is on about 80% of the set inside is powered up and running all out.
On these sets if you turn it off and the red light does not go out one of the relays on the power board is engaged or stuck in the closed position.
If I remember this model it has three black rectangular plastic relays on the power supply board(follow power cord into the set to see if this is the case.)
Relays have voltage and type marked on top (like 12 vdc etc).
Carefully with back removed what I would do is with something NOT metal tap on each relay until (with set turned off) the red light goes out.
That is the bad relay----if set has 3 I usually replace all as only 4 solder connections each and they are not real expensive.
I saw one of these sets where the customer had been gone for a month and when she returned set appeared to be off but Red light for power was on.
The set was so hot I tapped on the relays and then when I knew which was bad shut the set off and unplugged it to let it cool off.
I am saying if you leave the set plugged in and the red light is on There is the chance it may overheat to the point where you could have a fire.
Let me know if you have questions.
SD TECH
Sep 26, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
LC-23Y25 Problem with turning on power?
so i had the same problem. red light came on, but no blue light or anything on the screen. it turns out that there were some capaciters blown on the circuit power board. unless you have a good understanding of circuit boards, its not a quick fix. but for someone who knows their electronics, its not too hard, and its not expensive to fix, unless you bring it into a store. but the supplies needed arent expensive. good luck
Nov 09, 2008 | Prima C2012 TV
No picture on tv
Red light comes on but no picture
Aug 29, 2008 | Televison & Video
Protron PLTV-37 37 in. LCD Television Logo
101 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
