Question about KitchenAid Superba® Architect® KSRP22FS Side by Side Refrigerator
My water valve, ( a three solenoid) went haywire, I changed it and now it will not fill the ice maker, but I get water to the door just fine, I double checked my lines, all are right, what should I check now?
  • 311 Answers
The next thing to check would be to remove the line from the inlet valve that goes to the ice maker and blow into the line. Make sure the line is clear if you cant blow through it check your fill tub to make sure its not frozen. You could also try switching the wire harnesses for the solenoids (if they are both the same) and then call for water through to door (which in turn should fill your ice maker if you switched the harnesses) Then you would know that the valve is operating properly.
Hope this helps _MJ_
Posted on Feb 06, 2010
Refrigerator icemaker repair
The ice maker does its own thang. All it needs is power and a good water valve to supply the water. Also you paid the water bill helps too. Anywho when the temp in the ice maker mold drops below 25f the harvest cycle begins. The mold heater is activated and loosens the ice. When the ice starts moving the heater shuts down and the motor carrys over and drops the ice. The ice maker then asked for and gets water from the water valve. So what goes wrong? Watervalve solenoid burnt out, water valve dripping like a faucet make a stalagmite in the fill tube blocking fresh water to ice mold. If that is ok then something inside the icemaker went haywire, replace it. When replacing the ice maker replace the watervalve. Note: if temp inside icebox freezer does not get to 25f any ice maker new or existing ain't gonna make ice. Be sure to clean the coils down by the compressor and the kickplate so the maximum amount of airflow is running down there and make sure the cardboard panel back there is in place.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 26, 2013 | Dryers
Ice maker in Kitchenaid KSCS25FT does not refill. Makes ice cubes when filled manually. How to fix?
When an ice maker produces ice after filling with tap water and then cycles and does not refill with water that is an indication that the=> 2319734 Dual Water Inlet Valve
is defective. Replacing the water valve should get you back into the ice making business. The 2319734 Dual Water Inlet Valve has two sides. One side is for the dispenser and the other side is for the ice maker. When one side goes bad you end up having to change the complete dual valve set. Here is a link to a Whirlpool Ice Maker Trouble Shooting Manual Here is a link to another source for the 2319734 Water Control ValveI will be here should you have questions please ask, Thanks Sea Breeze
Apr 09, 2013 | Refrigerators
GE Side by Side Refrigerator model GSS25jfpa cc. No water to icemaker. Replaced the ice maker and the dual solenoid water valves. Still no water to ice maker? Water to door works fine.
if you can reverse the solenoid valve wire connections,then use the door water fill to activate this valve,but not long as it will overfill the icemaker,this will certify that theres water getting up to the icemaker,then it could be the maker itself not activating the icemakers water valve assy to fill the maker
Feb 01, 2013 | GE Refrigerators
I have model #TFX25PRYAWW. Ice maker is not filling with water. Water still operates through door dispenser.
NUMBER 800 is your water valve. It has 2 solenoids. One for water and one for ice. I suspect your ice solenoid is on the blink. It could also be dripping slowly like a faucet and clogging like a stalagmite the ice maker fill nozzle. The only other thing in the ice box that controls that water valve is the ice maker itself. if the water valve is ok then the ice maker ain't getting the power to that water valve solenoid.
Dec 17, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge s/s icemake floods water
Icemaker generally has only about a 6 second fill time. Most likely a particle made it past the screen in the fill valve and would not allow the internal diaphram in the valve to seal. You can't get to the internal parts of the valve. Replace the valve. Consider an in-line filter installation before the refrig hook up to prevent this from repeating.
Jun 14, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
I have a GE Refigerator (PSF26MGWA WW). the ice maker will not fill up with water. The tray heats up and the sweeper works. The fill solenoid for the ice maker does not work properly.The drinking water...
the ice maker is in control of the valve, however, the valve is one assembly containing the valve for the water dispenser and the one for the ice maker, take your model to the appliance parts store and get you a water valve assembly for your model number.
Dec 23, 2017 | GE Refrigerators
Ice maker wont fill
Hi, It sounds like the inlet valve needs changes. Could be the plunger inside the solenoid is not lifting to allow water through. If you remove the line going to the ice maker off the inlet valve, try and cycle the ice maker and put the inlet valve over a bucket to see if water is coming out when it gets voltage.
I hope this helps.Please let me knwo if I can assist you further.
Thanks
Vic
May 31, 2009 | Kenmore 53502 / 53504 Side by Side...
Ice maker won't work
There are usually two solenoids one for the water and one for the ice, you can trouble shot by switching the wires on the solenoids and see if you can still dispense water. If you can then the icemaker inside is where you problem is and it is easy to replace usually one elctrical connection and thwo maybe three screws and can be purchased online...
Jan 20, 2009 | Kenmore 55609 / 55602 / 55604 / 55606 Side...
Ice maker been working fine, just stopped?
If no ice is being made at all it is probably one of three problems. The ice maker itself needs replacing. The water inlet valve needs replacing. Or the freezer is not 10 degrees or less. You will need to test the water valve solenoids. If you have water in the door then there will be two solenoids. One for the ice maker water and one for the water in the door. They are both mounted on the same assembly. The easiest way for you to test is with a meter. You want to check for continuity on the solenoid for the ice maker. If no continuity, it is bad. If you have both water in the door and ice maker and no meter you can swap the two quick disconnects on the two solenoids and then see if you still get water from the door by now using the other solenoid. If you do not, then you know that, that solenoid is bad. If the soloind is good then you probably have a bad ice maker not calling the ice maker fill valve to allow water.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
No water for ice maker or at door
  1. Water comes from water pipe, usually with a shut off valve (open??).
  2. Fridge has a small filter (for sand etc.) at inlet. (not clogged??)
  3. Water travels to solenoid valve, and waits for request. (do you hear it click when water requested??)
  4. Water usually goes to a fine filter..(these fail (plug) quite regularly).
  5. Water goes through storage in back of cool section (Inside fridge- is it full of water?).
  6. Water goes to ice maker (door) on fill request.
  7. For Ice maker:
  8. ?? Is the power switch "on" (to icemaker)??
  9. ?? Is the full / stop filling paddle/bar up?
  10. ...ask me more questions
  11. In your case the solenoid valve or more commonly the filter need to be replaced
Apr 21, 2008 | Refrigerators
KitchenAid Superba® Architect® KSRP22FS Side by Side Refrigerator Logo
76 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
