Question about Microwave Ovens
I have a Chef Regal 90 Series Elevated Gas Cooker. I have fitted new igniter in the oven but there no spark to igniter? Can I obtain a manual online.
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: How to set and use
USING THE TIMER AND CLOCK
Using the 60 minute ringer timer
To set the timer:
1. Turn the knob clockwise to the required number of minutes. When the time has elapsed the timer will give a short ring.
NOTE: For times below 20 minutes, turn the knob past 20 minutes and then back to the required number of minutes.
Using the 2 hour cut-off timer
* Manual operation
The timer needs to be set at the "O" marker so that the oven can be used manually.
* Automatic operation
The 2 hour timer features an automatic oven "cut off".
This means that a cooking period of up to 120 minutes can be set.
1. Set the Oven Temperature Control Knob to the required temperature.
2. Turn the cut-off timer clockwise to the required number of minutes. For timer settings of less than 20 minutes, turn the knob past 20 minutes and then back to the required number of minutes. (Purpose - to set audible ringer.)
3. When the timer returns to "Auto Off", the timer gives a short ring and the oven will be switched off.
4. The oven will not operate again until you turn the timer back to the "O" marker.
NOTE: It is not recommended to use this timer for short duration, e.g. boiling eggs.
OPERATING THE PROGRAMMABLE CLOCK
WARNING
• The Clock MUST be set to operate oven.
General features
Your 3 button programmable timer has the following features:
• Timer - your 3 button programmable timer allows you to set a countdown time that will beep when the set time has elapsed.
• Cooking duration - You can set a cooking duration. A timer will count down the preset cooking time, beep when the time has elapsed and turn the oven off.
• End cooking time - you can set a cooking finish time. A timer will count down the preset cooking time, beep when the finish time has been reached and turn the oven off.
• Delayed start cooking time - You can combine the cooking duration and cooking end time to switch the oven on and off at a specific time during the day.
NOTE: Your 3 button programmable timer only operates
Change the time of day (Daylight saving)
1. Press the "mode" button until the "clock" indicator II begins flashing.
2. Press the - or + buttons to change the time. 5 seconds after the last change, the "clock" indicator II will disappear, confirming the time has been set.
Setting the timer
1. Press the "mode" button until the "timer" indicator II begins flashing.
2. Set the countdown time you want by using the - and + buttons. 5 seconds after the last change the "timer" indicator II will stop flashing, confirming the timer has been set.
3. To stop the beeper, press any button.
Setting the cooking duration
1. Check the clock displays the correct time of day.
2. Set the oven to the desired temperature. The oven indicator II light will glow and the oven will come on.
3. Press the "mode" button until the "cook time" indicator II begins flashing.
4. Set the cooking duration you want by using the - or + buttons. 5 seconds after the last change, the "cook time" indicator II will stop flashing, and the time of day will be displayed.
NOTE: Do not forget to add preheating time if necessary.
Setting the cooking end time
2. Select the desired oven function temperature. The oven indicator II light will glow and the heating source will come on.
3. Press the "mode" button until the "end time" indicator II begins flashing.
4. Enter the time of day you want to finish cooking by pressing the - or + buttons. 5 seconds after the last change, the "end time" indicator will stop flashing and the current time of day will be displayed.
Setting the delayed start cooking time
1. Program the "cook time" and "end time" as described in the relevant sections. Once both the "cook time" and "end time" have been set, the "cook time" and "end time" indicators will stop flashing and the current time of day will be displayed.
To check or cancel settings
1. To check your settings, press the mode button until the setting you want is displayed. A red light will flash next to the mode (cook time, end time etc) that is currently on display.
2. To cancel "delayed start" press the mode button until a light flashes next to "end time". Press and hold the - button until the clock no longer reverses (you will hear a beep). If you have left the temperature knob at a setting the oven will start once the "end time" light stops flashing.
3. To cancel "auto shut off" press the mode button until a light flashes next to "cook time". Press and hold the - button until the clock no longer reverses at ("0:00" and you will hear a beep). This automatically cancels "delayed start". If you have left the temperature knob at a setting, the oven will start once the "cook time" light stops flashing. Because you have cancelled "auto off" the oven will continue to heat until you manually turn it off.
On completion of cooking
The heat source will turn off, the timer will beep and the "end time" and/or "cook time" indicators will flash.
1. Turn the temperature control to the off position.
2. Press any button to stop the timer from beeping.
Accordign with the user manual. Hope this helps.
Posted on Jun 15, 2011
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
PAPER DIRECTIONS
That FCC number means it was made by Daewoo, but it may have a Magic Chef or other brand name.
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
For Magic Chef in Canada call 866.587.2002
Jun 05, 2013 | Magic Chef Microwave Ovens
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
Magic chef mcd990b,microwave, purchased 3-17-11 from kohls, need the manuel
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 17, 2011 | Magic Chef CHEF9 Microwave Oven
Where can I get an instruction manual for the Newholme stoves S1550Dom gas cooker
I hope this helps.
Mar 03, 2011 | Microwave Ovens
Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Nov 24, 2008 | Maytag MMC5000 Microwave Oven
Owner's Manual.
Yours may be here:
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
If not, try customer service:
Customer Service: 800.688.1120
Canadian Customers: 866.587.2002
Dec 05, 2007 | Magic Chef MCM660A Microwave Oven
Microwave Ovens Logo
147 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
