Question about ViewSonic VX2235WM Monitor
Monitor is not working. Computer has been turned off for a few days. Now after turning computer on, monitor has no display.
  • barbcole717 Feb 06, 2010
    No - there is not a green light. Only blue light.
    Will have to wait until tomorrow to hook up another monitor. Would have to be a tv monitor.
    Thanks.
    Barb
    President:
  • 3,278 Answers
Hello, Barb.
You didn't indicate if there was any power to the monitor (green light). Try flipping the switch on your power strip, if your monitor is connected to it.
Try connecting another monitor to your computer to see if your monitor or computer is the problem.
Could be the VGA cable (cable from monitor to computer) or VGA card (inside the computer).
Just some thoughts - please provide more details, if necessary.
Hope this helps.
Posted on Feb 06, 2010
  • NinaE Feb 06, 2010
    Hi, Barb.
    Also, try your ViewSonic on another computer ...
Screen scrambles
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jan 05, 2014 | ViewSonic VX900 19" LCD Monitor
When turn on color is great..after a few minutes turn blue and green
Sounds like the lcd is bad but here is a way to verify that. Hook up a known working monitor to the computer, if the colors stay great after a few minutes then you know the original monitor is good.
If the colors turn blue and green after a few minutes with the working monitor then you know for sure that the video card is bad and the video card would need to be replaced.
Aug 23, 2009 | Vision V1721B (Black) 17 inch LCD Monitor
LCD monitor turns black after a few seconds
I went through a lot of threads trying to come up with the solution to this problem, monitor goes off after a couple of seconds of just hitting the blue power button, and the solution I came to is the power supply within the monitor has gone out! which is common for flat pannel monitors, but I am not saying my situation is the same as yours, if you see different colors when it goes off on you, their is other problems wrong, mine has always been the power supply and I just take the monitor to a laptop repair guy and he charges me 65 flat to repair the issue. instead of going to viewsonic which they want you to send them and pay out of pocket first before they fix your issue. I will say 65 dollars flat and 3 days of not having a monitor is better then going to the ups store and paying 65 to box it and 70 to ship it. I guess look around for an electronics expert in your area and have them take a look at it.
Jul 29, 2009 | ViewSonic VA1930WM LCD Monitor
Computer keeps turning on and off, plus monitor won't display
Sounds like a loose wire inside the system touching something inside and shorting it out. My brother had this same problem. I brought it to my house to work on it and it was fine, no problems. Open the panel and look for any wires that are touching metal or something else and tie it up out of the way. I won't swear that is your issue, but sure sounds like it.
Jul 27, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Acer LCD Monitor - Stuck Displaying green
Cant say for sure. The display seems to be working, and the computer signal seems to be the problem. It could be a faulty cable. Check the pins on the cable monitor and see if they are bent, etc.
If the connectors are Ok, it could be the converter or the main board that has the fault. This could be caused by a power surge, or just a mechanical failure.
There is no easy diagnosis for this\ one, without actually checking the parts. I would recommend taking it to a repair place.
Jun 03, 2008 | Gateway FPD2275W LCD Monitor
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
May 14, 2008 | E-Machines E17T4 LCD Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
ViewSonic VX2235WM Monitor Logo
29 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
