Question about Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore elite oasis top load washer. When I came home from work it was beeping and flashing an f 8? code. I had not used the machine for 3 days. I turned the power off and 2 hrs later It started beeping and started to fill with water and spin with the top up. not flashing any codes. I stopped it then woke up 5 hrs later to more beeping and it had run another load, it is now unplugged. Any Ideas?
  • 11,896 Answers
F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock)
You can get the part and part number and replacement instructions at partselect.com and also repairclinic.com but partselect.com may be more informative for you.
Posted on Feb 06, 2010
How do I unclog the long drain Kenmore elite oasis?
Honestly, we got rid of the machine and bought a Maytag Neptune. I was over trying to figure out all the codes the Oasis was flashing. We gave up on the first one that started having problems when a friend gave us one identical to ours and it has done a lot of the same things.
Apr 03, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a model 27096 top load kenmore elite oasis he washing machine that keeps flashing code F2 and keeps turning itself on. Help
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I hadn't washed any laundry for a couple days and then my Kenmore Elite Oasis starting beeping in the middle of the night. My husband had to unplug it because it wouldn't stop. The next morning I did some...
According to the Whirlpool Cabrio (Sears Oasis) manual, this code indicates a "stuck key"
Keypad/User Interface Failure
F then 2 flashes when in:
• Diagnostics Test mode if a stuck key is detected.
• Standby mode if there is a user interface mismatch.
Following is the PDF of the manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Sep 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE. I keep getting a F2 error and a beeping sound. Will happen at anytime, not just when using the machine. Washer had been unused for 2 days and all of a sudden the error code just...
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Aug 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Sd error on my top load kenmore oasis
Unplug the washer for 6-8 hours. We were told to try this by a local repair man before bringing the washer in and it worked for us. He said it would reset the washer.
Jul 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
