Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Generator runs but will not generate, circuit breakers ok --wheelhouse 5550...worked ok when i got it new 5 years ago, i start it regurally but have not checked to see if it generated until now. it did genreate when i bought it
    Problem Solver:
  • 16 Answers
Engine has to run at 3600 RPM to make elecity.you shoud always put a load on the generator when the engine.
Posted on Dec 12, 2013
  • 59 Answers
Is the engine idle running at the rate it should? try manualy reving engine up to see if it will exite generation.
Posted on Feb 06, 2010
Husky 5000 watt generator quit producing power.
You could have a bad circuit breaker button. Replace that and see what happens.
Dec 24, 2015 | Husky Electrical Supplies
Sparking in power box when we use the generator and trips the braker
When you say "power box" do you mean the main breaker box in your house? Is the generator hooked up to the breaker that you say trips when the generator is on? There is a short somewhere. First check the generator. Is it running OK. In other words if you plug something into the generator receptacle directly, does it work? If the generator itself works properly, then check the wiring from the generator to the circuit breaker. DO NOT use the generator until the problem solved = safety first.
Jun 12, 2014 | Cars & Trucks
I have a Generac Wheelhouse 5550 watt generator that will not start. I put fresh gas in and sprayed the carb with cleaner. Upon further inspection, I noticed that there was some sort of relay near the...
is there a spark ? is the plug wet after trying to start it ? if not then check the main jet on the carb, people leave fuel in the carb when the genny is not in use which goes bad and blocks the main jet
Oct 31, 2013 | Electrical Supplies
Starts fine...no juice....sat for 10 years in the box...started using it 3 weeks ago...worked fine until yesterday....starts...runs..no juice...no circuit breakers blown...what's up?
Colemans were known for losing what is known as "residual magnetism", especially when sitting for long periods of time without use. This residual magnetism is necessary for exciting the field to produce electricity. Here is what you can try: Plug a 110v drill into one of the 110 outlets. While the engine/generator is running, with an open hand (not fingers wrapped around it) spin the chuck while holding the drill trigger in the run position. Many times this small amount of current that will be produced by spinning the drill motor will restore the residual magnetism and excite the field. Keep in mind that if this works, the drill motor will begin to spin immediately since it is plugged into the outlet. Hope this helps.
Mar 04, 2011 | Coleman Powermate Powermate 5000W...
Generator runs but can't reset circuit breaker
It probably isn't the circuit breaker. The magnetic field has likely weakened (especially if the generator has not been used in a while). The magnet can be "flashed" by running a current through the generator briefly. The easiest way to do this is to plug in a motor and spin it backwards (by hand) while the generator is running (e.g. an electric drill). The drill acts as a weak generator when you put the energy into it by spinning it.
A previous answer I gave to the same problem...
Look in the manual. There is likely something about field flashing the magnetic field2.gif. According to the Briggs and Straton web site (similar solution for all generators), the easiest way to do this is to.
1) start the generator
2) plug an electric drill into the generator (without drill bit)
3) make sure drill is set to forward direction (if a reversable drill.
4) pull the trigger on the drill.
5) If the drill does not start, spin the drill's chuck in reverse [clockwise (When looking down at the chuck from the drill bit end). Spin counter-clockwise if holding it like a pistol and pointing away from yourself].
6) Do this several times (hard) until the the generator will kick in and suddenly make the drill spin at full speed.
Be careful not to drop the drill or poke someone with it as you celebrate success.
Oct 27, 2009 | Coleman Powermate Premium Plus 6250W...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Jul 20, 2008 | Dometic Rooftop RV Air Conditioner
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
387 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
