Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer makes loud bumping rattle noise
  • 311 Answers
There are a couple of possible causes of noise on neptune dryers. One possible cause would be a loose blower wheel and the other possibility would be bad rear rollers. If you open the door and take off the 2 screws that hold the door in place then lift up slightly and pull the door off. Then you will see 2 screws on the opposite side remove those. Then you can pull the front panel off. There will be 4 5/16 screws around the panel that holds the front of the drum in place. Remove those screws and the front housing will come off. (Check the tefflon glides on the at the bottom of the housing that the drum rides on for wear)
You can then see the blower wheel in bottom left it looks like a hamster wheel. If you spin it by hand it should be securely attached to the shaft. (usually if they are bad the center wears out and it will spin freely on the shaft). The blower wheel part number is probably Y303836.
To access the rollers you will have to reach in and remove the belt (pay close attention to how the belt goes on some models can be very tricky to get the belt back on properly). Most of the belts on these go around the drum with the ribs facing up. Then you should be able to pull the drum right out. There will be 2 rollers at the rear of the cabinet that the drum rides on. Spin these by hand and if they are making squeaking, squealing, or hard to turn they need to be replaced. Be sure to lubricate the rollers with silicone grease or any high temp grease.
To replace the rollers or the blower wheel you will need snap ring pliers to remove the snap rings that hold them in place.
Good luck hope this helps _MJ_
Posted on Feb 06, 2010
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
My dryer makes a loud sqeeling noise when its drying clothes our maytag neptune is a gas dryer thats about ten years old
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghgh
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
A loud rattling noise occurs when the dryer is running
heatman101
fjd
Dec 13, 2009 | Maytag Neptune MDG6800 Gas Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dc
I have a Maytag Neptune drying center. The top unit is making a very loud banging noise. How can it be repaired, is this a common problem?
Apr 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
37 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
