Question about Sport & Outdoor - Others
Driving belt gilson snowblower
The driver belt of my gilson snowblower broke to day. how do you replace it?
5 Suggested Answers
SOURCE: The serpentine belt broke replaced it and i broke
I had this problem, it turned out that A/C compressor had seized and wouldn't turn, because the compressor was stuck it would rip up the new belt- so you can one of two things;
replace the compressor and belt
or
get a shorter serpentine belt and bypass the A/C compressor- there are several sites that show you how to route this.- i did this being a college student, not having A/C isn't that bad
Posted on Nov 20, 2009
  • 7 Answers
SOURCE: Older Wards GILSON Snowblower. Just replaced AUGER
no, they are self-adjusting. you probably got the wrong belt
Posted on Feb 18, 2010
ToolBoxHero
  • 171 Answers
SOURCE: I broke a belt on
First, are you sure you broke a belt or did you break the shear pins in the auger?
I am going to assume you have a 2 stage snow blower. Here is a manual for a "typical" two stage blower. http://www.managemylife.com/mmh/owner_manuals/12649/CRAFTSMAN-Snowthrower-Gas-L1001285?brand_name_search=craftsman+88957
Your blower may be a different color or make, but changing the belts will be basically the same.
Follow the instructions in the manual.
If you have a single stage send me the make and model number off the nameplate and I'll walk you through the belt change.
I'll be glad to answer any other questions or help you though this repair.
Posted on Jan 06, 2011
  • 12 Answers
SOURCE: my snowblower belt broke. How
Rotate the snow blower forward so it rests on the front intake with the tiller, there should be 4 or so bolts holing a rear lower plate on the immediate back of the blower. Remove them and you will see the pulley system where the belt goes. depending on the model, you'll see the adjustment wheel that may need to be loosened, most are simply tension. If you have the belt, bring it to a dealer, agway, etc and buy a belt. If no belt, measure with a piece of string. reverse the procedure to install.
Posted on Feb 28, 2011
Recently lost my forward drive gears on the snowblower that was previously working.
You are not clear about what is happening but check your drive belt. Mine broke and when I replaced it every thing worked.
Dec 29, 2015 | Garden
Tecumseh 8hp drive stopped have to push
Could be the belt is broke or come off or the pully loosened on the shaft. Good Luck
Jan 04, 2014 | Tecumseh Snowblower Snow Blower Starter...
Snowblower auger stopped with a bank
Check the belt that is used to drive the auger because it probably broke. If there is no belt check the drive shaft to make sure there is no a broken shaft.
Dec 30, 2012 | Garden
Gilson snowblower manual
Try brentchalmers.com they have manuals there you will need model numbers
Nov 18, 2012 | Garden
Have a craftsmand 24" snowthrower
If the motor runs well, the two most common causes of this are the drive belt is worn and/or the shear pins are broke.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission. It sounds like you need to inspect the blower belt.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Replace the belt if it is worn, stretched or frayed
The shear pins are located on the auger in the front of the machine. Your newer Craftsman has four. If you don't now about them look in your operator's manual for the location. You need all four for the snowblower to work well. Replace the missing ones.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman Garden
How to change drive belt-Ariens 522 snowblower-model # 938017
Which belt? You are referring to the auger drive right? The self propell uses a friction disc drive.
The auger drive has two belts, and in order to replace them you need to seperate the auger from the engine (split) the blower.
Happy days.
Matt
Dec 13, 2010 | Garden
Broken belt
The web site below sells Gilson belts - you need the part number. If you do not have the part number, maybe if you contact them, they can match the belt to your tiller number.
http://www.psep.biz/store/gilson_tiller_belts.htm
Also, another web store, Jacks small Engines (jackssmallengines.com) states that they carry parts for Gilson, but I did not find Gilson in their directory. You may have to contact them.
One of the web sites mentioned that at some point Gilson was bought by Lawn Boy. If you go to a local Lawn Boy dealer, they may be able to match up a belt.
I have a 1978 WheelHorse tractor. The drive belt for the mowing deck broke. I went to Home Depot, spend a good 1/2 hour measuring belts, and found one that works perfectly. If you go to your local outdoor equipment shop, especially one that sells, repairs tillers, they may be able to match up a belt for you. A belt is a belt is a belt. If you go to a "good old fashioned shop" that will spend the time, they can measure the old belt and hopefully come up with a match.
Good Luck!
Jul 29, 2009 | Garden
Just need to see the order in which the parts go back on the drive assembly for a Ward/Gilson 1575 front tine tiller
which drive assembly do you need info on,the belt drive or the gear box/case ***'y,I have a manual and can send a pic if needed,plus I have microfiche also on most of the Gilson jed1950@earthlink.net
Jul 16, 2009 | Garden
Ariens 926LE snowblower won't engage forward or backwards. Running fine
First thing I would check is to make sure the traction drive belt didn't fall off or break. To do this remove the plastic shroud between the engine and the snow chute. The traction belt is the one closest to the engine.If it isn't broke Make sure it is on the upper and lower pulleys.
Dec 21, 2008 | Garden
Sport & Outdoor - Others Logo
114 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
