Question about Hitachi Televison & Video
Have a hitachi ultravision digital tv. model
Have a hitachi ultravision digital tv. model #53UDX10BA. Wouldn't come on after turning off one night when it was working fine. Clicked several times when power button pushed. Called repairman out. He took back off, checked everything, put it back together and it worked fine. He said he had never seen anything like it and according to his testing, could find no reason for issue. Next day wouldn't come on again and he won't come back!!
  • 6 more comments
  • robinjohn446 Feb 06, 2010
    do you have the picture of what i am loking for?
    we found the S901 & S902 relays. We tapped on them, turned the tv on, heard the clicking but tv didn't come on. what now?
    we kept tapping and tv is now on. we will order and get our non-help repair guy back out here! think this is all it is?
    solders all seem good?!
    trying to get it back on and can't! order parts directly from hitachi? will try to do it myself..what about the soldering?
    going to order the parts! thanks so much for your help!!
  • robinjohn446 Feb 11, 2010
    just recd S901 & S902 relays. installed. tv still not working. clicks when turned on. what now?
    have checked all connections including my most recent. all appear to be fine. NO IDEA where to start looking on power board?? what should i be looking for?
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
There is one very common problem in this set that may be your problem; it uses two mechanical relays and they usually are mounted on the power supply board---if I remember this model there will be a circuit board mounted (as you look from the back of the set) on the right wall--the power cord goes to it. Lots of times one of the relays will stick either open or closed (closed would give you a problem where the power light would remain on even if you turned the set off). I am going to post a photo here of what these parts look like--not exactly yours--but you will know what to look for. What happens sometimes is if someone opens the set and taps on the two relays the set will work again until the relay acts up again--if you find this is your trouble---the relays are easy to replace and about 4 dollars each from Hitachi--any good tech should have been familiar with this problem as it is very common. SD TECH Hitachi FJ00142 S901,S902 RELAY, POWER/AUDIO
Posted on Feb 06, 2010
  • 6 more comments
  • SD Tech
    SD Tech Feb 06, 2010
    Should be with the last post.
    Let me check here.
    SD TECH
  • SD Tech
    LETS TRY IT AGAIN.
  • SD Tech
    YOU should be able to see it now.
    SD TECH
  • SD Tech
    Most likely either one of them is totally bad now or you have a bad solder connection on that board; if you are able to remove the board look at the bottom where they are soldered in--each relay has 4 solder connections--look to see if any are bad or cracked (the connections0>
    The fact that someone came out and opened the set and it started to work again suggests a physical problem of some kind--either a bad solder connection or something loose.
    SD TECH
  • SD Tech
    Yes, if it came back on a very good chance; problem for me has always been to try to tell which one was bad--at the cost of the parts cheaper just to replace both---
    This could be a do it yourself job......It you get a tech make sure he gets the part number and comes with two---only way to be sure if they are the problem is to replace them and see what happens but I have seen about 12 of these with this being the problem.
    SD TECH
  • SD Tech
    only 4 pins on each relay--fool proof---two pins side by side and other two diagonal--no way to put part in wrong---GOOGLE THE HITACHI PART NUMBER AND SEE IF SOMEONE HAS THEM ONLINE--quicker to order them that way---any good soldering iron should do the job.
    If I had the board out at that time I would also take a very good look for any other solder connections that might be bad on the board.
    SD TECH
  • SD Tech
    SD Tech Feb 11, 2010
    BEGIN by taking the power board back out and looking carefully at where you soldered and also at the other connections on the board.
    If not there, suspect bad connection on main board below.
    SD TECH
  • SD Tech
    The deflection board with the part with the large red wires coming out
    of the top is where you want to look next--That is the high voltage transformer---it is a large board!
    You are looking for something obvious--solder connection ringed
    (hairline cracks in the solder around some part or connection) --it may
    even be slightly burnt---you have to look closely.
    SD TECH
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
