Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Cut cord with mower by accident. connected new cord but no dice. is there a reset button?
    President:
  • 949 Answers
Did you check the outlet, you might have tripped the breaker,
or you fried the outlet.
Plug the mower into a outlet that you tested with a lamp or something
so your sure there is power at the outlet, and at the end of the extension cord, if there is power to both but not the mower, contact the company because there is no reset button.
What ever outlet you use to plug this thing into, you should have a ground fault outlet installed, for two reasons, safety for you, and protect the mower.
Posted on Feb 06, 2010
Testimonial: "The breakers were ok so I plugged a coffee grinder in to the outlet and it didn't work, so I switched outlets and voila!"
I have a tandem pacer 2400 lawn mower, my gardener was cutting fairly wet grass, it tripped the power and now does not start, even left it for a few hours ? thank you Vanessa
have the lead to the mower tested and tagged
if there is any insulation problems in the lead , then the rcd breaker will trip from earth leakage problems
wet grass is very heavy to cut so the motor may have overheated
press the reset button if it has one or have the electrician doing the test and tag of the cord also check the motor
moisture and power do not mix so electric mowers are only suitable for dry cutting
Jan 14, 2017 | Garden
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Ran over power cord and now won't start with new cord.
did the breaker on the plug your using trip?do you have a gfi outlet that tripped?
Jul 01, 2012 | Garden
I have accidently cut the electric cable on lawnmower..can it be fixed
hi there pauly 46 here
your answer is yes
BUT ! -- it it is something that cannot be endorsed as a safe repair or recommended
for a electric lawn mower such as yours - the best option is to buy a new complete cord set
as a electrical repair shop would not want to take the risk of possible electrical shock
if repair was to fail in use
and more so the ends of those cords are molded and cannot be replaced seperatly
off the top of my head a new cord could set you back about 100 $ possibly ?
sorry for the bad news
cheers pauly 46
Apr 28, 2011 | Electric Lawn Mower
Hoover c1810 bagged upright - power keeps cutting out - is there a reset button?
there might be a reset button on there but its not meant for continuous use. we need to figure out the problem why the power cuts out. what condition is the cord in? cuts nicks. also check the prongs on the plug. if not that could be a bad switch but it sounds like a loose connection
Jan 02, 2010 | Hoover Commerical Conquest C1810 Bagged...
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Black and Decker 18 inch electric lawn mower turned off
Try the link at the bottom of this page : "Find Manuals".
Jun 11, 2009 | Black & Decker 18", 6.5a Electric Mower
Electric mower not starting.
I have no idea if your problem is related to mine, but my B&D electric mower did the same. The cord worked on other equipment so wasn't a bad cord. It turned out I had to get a higher amp cord for the mower. Why it worked for a while on the other cord I don't know but I've had no further problems with it. The cord was expensive though.
May 19, 2009 | Garden
Phone cord replacement
Any standard phone cord should work no problems.
Aug 20, 2008 | Thomson GE-28115FE1 Cordless Phone
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
116 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
