Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Dirt Devil Bagless Upright - where does hose attach?
There seems to be no place for the hose on a new, Dirt Devil Bagless Upright to be affixed for suction to kick in.
Is a design flaw? Where I think the hose goes, has no suction whatsoever.
H-E-L-P!
debbily
  • 101 Answers
SOURCE: Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Posted on Oct 11, 2007
SOURCE: dirt devil en vision
download manual here
http://www.dirtdevil.com/CustomerService/Manuals/
Posted on Jun 24, 2008
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Posted on Jul 30, 2008
galati2k
  • 281 Answers
SOURCE: I have a dirt devil featherlite bagless vacuum;
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt travels.is the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
Posted on May 05, 2009
Locate model no. at the rear bottom of the vacuum.
Then go to Dirt Devil site: http://www.dirtdevil.com/CustomerService/Manuals/
(this site will not find the manual under the name, just model #).
Posted on Nov 18, 2009
Why is my Dirt Devil Vacuum Hose lacking suction?
I have a Dyson and was having a similar problem some time back. I found out these bagless systems still have a filter that picks up the fine dust to keep it contained. Find out where yours is located and beat the dust out of it really good or just replace it.
Hope this helps.
Mar 10, 2014 | Dirt Devil Vacuums
Sounds stupid but how to i connect the hose?
the hose on a dirt devil upright attaches on the side near the bottom of the plastic container that hold the dirt; that end goes in and gives suction to the power head.the other end goes on the other side closer to the top of the plastic container again on the side. If you look at the bottom of the machine you should see a hose going from the power head to the machine and it leads up and attaches to the long hose. It is the other side it attaches near the suction to create the air flow. You can also check your owners manual.Thanks and good luck. If this helps don't for get to click on the yes box on your way out.
Oct 08, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum won't pick up
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
Hi my dirt devil vision vacuum is having problems. I turn it on and its sounds like its working, but it is not cleaning. Is there a quick fix?
Check there is no blockage in hose. If bagless check filter they clog up quickly I personally dislike bagless vacumns
Dec 18, 2009 | Dirt Devil M088905 Vision Bagless Upright...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Dirt Devil Purpose for Pets won't ****!!!!
The filters will need cleaning. Make sure the entire cone filter has been gently brushed getting rid of all dust. Also check in the main dust channel where the beater bar is. It may well be clogged and best to check the hose too.
Jan 31, 2009 | Dirt Devil Featherlight Bagless Upright...
Dynamite Dirt Devil Hose
I figured out how last night.
Take a screw driver and unscrew the screw on the top of hose and take the hose out and take a pen or something long enough with grip to get all of the junk out.
The circulation still isn't as strong though.
Dec 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
DIRT DEVIL VISION BAGLESS UPRIGHT
Check further down, by the brush roll, the inlet may be clogged, or something like a nail or pin wedged sideways in the hose, and catches debris and clogs up. This has a one year warranty, if you still can't firgure it out, take it to a warranty shop and take proof of purchase with you.
Dec 29, 2007 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
259 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
