Question about LG 42PC3DC 42 in. Plasma HDTV
My picture suddenly appears very dark and where I can see the picture...it has a reddish tint... Can i replace a board or two to get the picture back...I am willing to buy the boards...just need to know what to replace....
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. A plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. X, Y sustain, buffer boards controls picture, fires the gas, and many others functions. When either of these boards goes bad common problems include negative image, no image, vertical or horizontal stripes on picture, turns on and than turns off, and many more. You’ll need to open the back off the TV and check for any swollen/bulged/leaky capacitors on these boards and replace whichever has gone bad. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 05, 2010
My pictures have a reddish tint to them
If your pictures that have the reddish tint are taken indoors, the tint is likely caused by the lighting. You can set up a 'white balance" adjustment to fix that.
May 02, 2015 | Nikon D50 Digital Camera
Jvc hd projection tv screen is tinted pink/red PLEASE HELP!!
not so sure if warped lines about it not being convergence, if the lines are diagonal and light red etc it may be a screen circuit issue. Hard to tell from description----take a few good photos and post them on a free photo sharing site and provide a link here---expert who sees what it looks like may be able to help...............
Sep 02, 2012 | JVC Televison & Video
My Sony KDL-32M3000 has dark reddish picture, checked the ribbons around the frame they're ok, power supply is ok, Hi voltage board is ok, I'm guessing the main video processing board since I don't have a...
It will be either BM board (Video Processor board) or Tcon Board (top side of panel). I have similar problem...my TV turns on, lamps turns on (you can see them from back side panel holes) but just a dark blue picture appears with no image (like picture when external input is selected without signal), no OSD appears....some times I can heard audio (using Antena).
I'm thinking getting the BM board.
Dec 25, 2010 | Sony KDL-32M3000 32 in. LCD Television
My toshiba 61h71 has a reddish tint to it. Turned it off one night and it looked fine, next morning it got this reddish tint. Tried resetting the convergence but that didn't change the situation at all....
A Reddish tint means that the Green signal is missing. Does the on screen menu look normal? If so, this points to the signal source. The fact that this happend suddenly, I would check your cables first.
Using YUV?
If the TV's Menu also looks reddish then there is an internal problem with the display.
Good luck
Dec 30, 2009 | Toshiba 61H71 61" Rear Projection...
Slow picture and dark reddish tint
These sounds like you have an issue with main board or tcon. Picture slow makes me think this is a communication issue between the tcon and the main board.... This needs a professional diagnostic. The good news is i don't think it is the panel which would make the cost of repair beyond the cost of the tv. If it is in warranty or just out of warranty call sony, sometimes if it is just out of sony's 1 year warranty they will make exceptions. But you need to call them for this exception.
Some solutions are not cut and dried and an on-site diagnostic is best. In your case this is true. I have worked on sony for many years and that symptom (at least the way it is described) is not one I have seen.
Oct 10, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Monitor went dark
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 25, 2009 | Toshiba Satellite A135-S2386 Notebook
DARK AND COLOR RED
It is more than likely a convergence issue rather than a color issue.
Jul 19, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Poor quality pictures
Check your picture settings, the wrong setting for the time of day or object can definetly throw off the appearance of your pictures. Plus, you may have accidentally set it to "warm" instead of auto or black and white, etc. Warm pictures have a reddish tint to them just as the cool have a blue tint. Also I have found the "night setting" only takes really good pictures if you are close to the subject otherwise it is pretty dark!
Aug 16, 2008 | Kodak EasyShare CX7330 Digital Camera
LG 42PC3DC 42 in. Plasma HDTV Logo
500 people viewed this question
Computer Repairing
Computer Repairing
