Question about Mitsubishi VS-6041 60" Rear Projection Television
Need to remove the frame so i can replace the diamond screen
3 Suggested Answers
  • 2920 Answers
SOURCE: Where to find replacement Diamond Shield at reasonable price
you will need to go to the dealer they can order it for you
Posted on Aug 10, 2008
thaurfen
  • 623 Answers
www.productshub.com
or call 411 for nearest dealer
or 1800-555-1212 toll free for atnt subscribers
The screen shield of my mitsubishi HD 1080 diamond projection tv is scratched and shows rainbow color dots in some places. What can I do? Can I fix it? Replace it?
The outer screen on most models is clear and called a protective screen and prevents glare---if it has that it has 2 more screens behind it.
Getting at the outer on is not so easy---the entire frame for the screens has to be removed, the inner screens removed to get at the outer screen to remove it (if 3 screens you can do without the outer one except if it got scratched before--next will be the next screen behind it.
Check with mitsubishi to see if the screen that is damaged is available or not.
Oct 29, 2012 | Mitsubishi Televison & Video
Check this link I believe they can help you with this http://fixmymonitor.com/
Hope that helps..........
Aug 01, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Screen is non-functional and irreparable
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
hope this helps
Sep 17, 2012 | Computers & Internet
I replaced my Mitsubishi 55 diamond and don't know how to get the back top portion off to get it out of the house. it's too wide and no screws found? Please help
THE SCREW HOLES ARE COVERED WITH PLASTIC CAPS TAKE THEM OFF IF YOU DON'T SEE THEM YOU NEED TO TAKE THE FRAME AND SCREEN OFF FIRST AND THEY WILL BE ON THE INSIDE OF CABINET.
Oct 12, 2011 | Mitsubishi WS-55908 55" Rear Projection...
The diamond shield has been damaged and looking for a replacement
you can get a cheap replacement protective screen at a local plastics company. you will have to cut it yourself with a cut-off wheel and dremel. or you can have them cut it for you. the original protective screen is to expensive to worry about at this age of the set. check the yellow pages for a local supplier for plexiglas/clear plastics 1/8" or 3/32" clear its cheap!!! and all you need is a phillips head screwdriver to replace it.after you remove the speaker grill there are 4 screws on the bottom of the screen frame. then you lift the frame straight up and it comes out. inside there are brackets holding the screen in place. be very careful not to damage the screen.
Jan 07, 2010 | Mitsubishi WS-65819 TV
Diamond screen
Not sure why you want to remove the protective screen but to do this you have to remove the entire screen with frame and all 3 screens from the set. remove speaker grill(s) on front of set; you will find if the front control board is in the frame of the screen you will have to locate one or two plugs to disconnect the keyboard--the wires usually go down in past an inspection plate and can be unplugged(they are marked with letters and if two, they will be different so you cannot get them in the wrong way).
With the keyboard unplugged you will find several black philips screws on the bottom edge of the screen frame(left to right under it). Remove these and with help lift the screen unit(frame and screens) up about 4 inchs(it hooks inside on notched holders) It will then come out.
Now the hard part---most of these sets you have to remove both inner screens and even take the screen frame apart to get at the front screen---any finger prints on the screen may show in the picture.. The protective Screen is in a slot all the way around--I have seen a few who tried to pry it out from the front and either damaged the frame or the screens.
Again, I am not sure why you want to remove the outer protective screen---but just be careful if you do---those inner screens are very expensive if you have to replace them.
If this has been helpful at all--give me a vote here---I do this for free.
If you have questions or need help:
etower.766@netzero.net
Aug 23, 2009 | Mitsubishi VS-50705 50" Rear Projection...
How do I replace the LCD Digitizer screen on a HTC Touch Diamond?
Dont replace it. Go to ebay and buy a bad one and replace front ends
Aug 04, 2009 | Computers & Internet
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Screen replacement
Post a email link and I will email you the page from the service manualshowing the disassembly proceedure.
Jan 27, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
