Question about Balance CM2019 19" LCD Monitor
I have a Balance CM2017 19" LCD Monitor
My monitor all of the sudden it went black and shows no power. Would you say that the power adapter went out?
  • Plumcrazy1 Sep 04, 2008
    Monitor shuts off at any time and won't turn back on.
    The orange light is lit but the green light won't stay on.
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
I have a 19 inch samsung monitor. suddenly it went dark. Can it be repaired?
Please be more specific about your problem:
1. Is it black or just darker by lower brightness? 2. Is the power led turned on and what color is it showing?
Sep 14, 2011 | Samsung 19" TFT LCD Monitor...
I had been using my computer when all of the sudden screen went black and I could hear the windows shutting down. I thought maybe my battery was dead and I was not paying attention, so charged it. But when...
Do a hard reset by turning off the computer and removing the battery and unplug the AC adapter. Without any power source, press and hold the power button and put everything back after. Power on the computer again, if it does not work, try to connect your laptop to an external monitor. If it shows some display it means that the LCD monitor of your laptop has gone faulty.
Aug 30, 2010 | Dell Inspiron Mini 10 Notebook
Power failure issues
The specs for this monitor is a 60 Watt, 12 Volt, 5 Amp power adapter. The voltage must be the same. You can always get an adapter with a higher Amperage rating, but never get one with less, as this can overheat the adapter and damage it. I was not able to locate specs on whether the voltage to the monitor is DC or AC... most are DC. If this is the case, the observe the polarity at the monitor. Power adapters have a positive and a negative... center and outer contact, Make sure that the power adapter matches that of the monitor, else it will not work.
Sep 26, 2009 | Balance CM2017 17" Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Nov 01, 2008 | BenQ FP91G+ 19" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Balance CM2019 19" LCD Monitor Logo
218 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
