Question about Gateway Essential 400 PC Desktop
The sound on my Gateway computer is distorted, crackly or echoe like sound I tried new speakers and same problem. I tried to uninstall (Sigmatech?) and reinstall, no help.
Hello have you tried a new sound card perhaps they dont normally go but never no i had one go on me
Posted on Feb 06, 2010
Sound is distorted and echo's
check the speaker plug/outlets is usually if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is or a can of compressed air
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 29, 2012 | Compaq Presario CQ57-410US 15.6-Inch 320GB...
Sounds like polarity is wrong on one of the speakers?
you have to make sure the speaker's are connected properly (positive out to positve in negative out to negative in)
Jun 04, 2010 | Yamaha HTR-5730 Receiver
The speakers sound like an echo and you can't understand what is being said with everything being distorted. The monitor has not been in use for a few months and everything else is working properly, but I...
Have you checked the sound with some other speakers or a headphones.
If the sound is still like echo try adjusting audio settings not thru My Computer - audio, but try finding a software that comes with *********** board/sound card. I suppose the sound is some AC97/Realtek compatible card, so you should looking in your program files under Realtek into WDM and run the Audio Control Panel or Sound Manager (whatever you find). Adjust the sound effects to NONE and use some normal enviroment (other then echo/cave/big hall).
May 22, 2010 | ViewSonic Computers & Internet
Distorted, cracked sound coming through to the speakers
is it possible your new reciever has a built in phono pre-amp?
If so, you need to switch off the pre-amp inside the turntable (lift up the rubber matt, and rotate the plate untill you see the switch at the back)
Try again now?
Feb 12, 2010 | Aiwa PX-E860 Turntable
Audio is distorted
try to reinstall the driver that all and hope this will work fine.
Oct 07, 2009 | Audio Players & Recorders
Distorted sound.
You can try shutting off Audio Hardware Acceleration.
Start > Control Panel > Sounds and Audio Devices > Advanced (Under Speaker Settings) > Performance.
Let us know
Good Luck
Apr 14, 2009 | Audio Players & Recorders
Distorted audio from pc dvd-rom playback
Try getting new speakers before you throw it out the window....lol
Mar 11, 2009 | Dell Dimension 4600 PC Desktop
I pluged in my speakers but the sounds are very low and wierd
you cant get echo on a specker there not made for that just normal sound
Nov 16, 2008 | Ozaki DT-500 3-Piece Speaker System...
Video conversation ECHO/Feedback
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using headphones during videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Nov 04, 2008 | Logitech Webcam
Unbalanced sound
hello there!
First things First
1) you got a 5.1 sound card?
2) Direct X 9.c installed?
3) On control panel and multimedia, change to 2 speakers, that should work.
ano other than these is a bad pair of speakers! time to buy new ones.
Open Sky
Feb 23, 2008 | HP (ZD929AA) Computer Speakers
Computers & Internet Logo
67 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
