VP191B VIEWSONIC MONITOR POWER ON AND PICTURE SHOWS FOR HALF A SECOND THEN GOES BLANK, POWER OFF AND POWER ON PICTURE FOR HALF A SECOND AND GOES BLANK
  • Louis Ebert May 11, 2010
    randy927, Nothing new here. You did a nice description of NOW!!! But no info on unit HISTORY!! How old? Approx total ON hours of use??? Will you do the REPAIR work?? Have 25-40 watt soldering pencil?? Now all you need to do is rumage around in my FIXYA PROFILE and discover ALL you need to know just by doing some READING. Then if that's not enough you can surf to any of the links you find in my profile for even more info on what to do. Your "cold-cathode-fluorescent-lamp" back-lit LCD display is NO DIFFERENT than ANY other BRAND in it's BASIC design and operation!!! Read! Find out why your ACER works, JUST not long enough!!! 12fixlouie
  • 11,361 Answers
More likely to have problem in either the backlight light inverter board or bad lamps due to poor solder connections, see http://s807.photobucket.com/home/budm/allalbums
You will need test lamp to narrow down the problem.
Posted on Feb 08, 2010
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Viewsonic n2750w turns off half a sec after power on, still sound
THE 1000 UF CAP IN THE POWERSUPPLY IS BAD MOST OF THE VIEWSONICS HAVE THE SAME PROBLEM EATHER THE 1000 UF CAP GOES BAD
OR THE 470 UF CAP GOES BAD DEPENDING WHICH ONES YOU HAVE
Mar 22, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
VP191b monitor no video Viewsonic
did you activate the monitor port?
Did you check theconnection?
Is themonitor pluged in the wall socket?
Jan 16, 2010 | Computers & Internet
Monitor displays then shuts off
Have you verified the video card in the computer with a different monitor? Does the going to sleep message come up prior th the monitor going dark? The bulbs are ok since you do see a picture for a short time. The voltage swing you see on the power supply is too large. It should always be 12 v + or- 10%.
Mar 28, 2017 | ViewSonic VG900b 19" LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Viewsonic va1912wb monitor goes blank for few seconds and comes back and this happens very often
Your power/inverter board needs to be overhauled.
Your capacitors on the board are probably burned out.
If you open it up and send me a picture , I may be able to tell you if they are or aren't.
There is also a chance a transistor has gone bad on the board.
I repair many viewsonic boards on ebay
bammbammfran
Oct 21, 2008 | ViewSonic VA1912wb Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
