Question about Car Audio & Video
Installing a pioneer stereo in a 1995 honda civic
I only have 2 wires left which are the black wire which has a hook for a screw which is the ground and a blue wire with a white stripe, the end has  a clear rubber connector it also has a tag on it that says system remote controll on the directions it says connect the black wire to the chassis of unpainted metal. what if i can not find metal to attach the ground then where do i connect it to shouldnt i just connect it to the black ground wire of the car?  the blue wire has a connector do i just connect that to the solid blue wire of the car which says power antenna
  • hcory1978 Feb 21, 2008
    thank you for your time i really appreciate you help
  • Anonymous Jun 08, 2008
    which wire is the power wire in the 1995 honda civic
  • 43 Answers
I'm assuming that you're connecting to a wire harness that you've purchased and not directly to the wires which were plugged into the original Honda radio.
The black ground wire from the Pioneer can be connected to the ground wire on the car. You are correct on the blue/white remote turn-on wire as well - it can be connected to the blue power antenna with no harm. If you were installing any amps the blue/white wire would also go to their remote turn-on input.
Posted on Feb 21, 2008
Stereo wiring on 1993 honda civix dx
I hope you like colors.. thats the speakers.. powers easy
black : ground .. red: hot wire to fuse box with hopfully a fueable link..( ever see them wires wit a fuse in middle) fuseable link..
Id run it all off that . make sure u find a power source thats always on. or it b 12: allday long
May 09, 2012 | Pioneer Car Audio & Video
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1995 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1995
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fuse Panel
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWM: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
What is the color code for wiring of 1999 honda civic
Honda Civic Stereo Information Constant 12V Blue/White Switched 12V Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front ( ) Blue Left Front (-) Gray/Black Right Front ( ) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear ( ) Blue/Yellow Left Rear (-) Gray/White Right Rear ( ) Red/Yellow Right Rear (-) Brown/White
Mar 07, 2011 | 1999 Honda Civic
Is there anyone who can answer a question re color codes for matching wires from harness to stereo i have a pioneer stereo and and need to install it in a honda civic need to match its wire colors to...
hoy cr*p. Thats a big question. I'm used to the simple hook up of red = hot wire, black equal ground wire, and white usually goes to the speakers. MOST electronic equipment use red as the "hot wire"...or the wire that is the main electrical wire. If your colors dont match, you might talk to a shop that specializes in installing car stereos. Good luck. thats how they make their money, but depending on the price you may decide not to mess with it yourself. Just label the wires with tape when you find out.
Nov 06, 2017 | Pioneer Car CD Receiver, DEH-16
I need the stock wire diagram that connects to the car stereo for a 2000 honda civic
2000 HONDA CIVIC FACTORY RADIO WIRE COLORS
BATTERY WHITE/BLUE
ACCESSORY YELLOW/RED
GROUND BLACK
ILLUMINATION RED/BLACK
LEFT FRONT SPEAKER BLUE/GREEN(+) GRAY/BLACK(-)
RIGHT FRONT SPEAKER RED/GREEN(+) BROWN/BLACK(-)
LEFT REAR SPEAKER BLUE/YELLOW(+) GRAY/WHITE(-)
RIGHT REAR SPEAKER RED/YELLOW (+) BROWN/WHITE(-)
Oct 10, 2010 | Car Audio & Video
I need the radio wiring diagram for 88 honda civic hatchback
1988 Honda Civic Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Here can find the Stereo Wire Harness OEM Honda Civic 86 87 88 89 90 (car radio wiring installation parts)
Hope help with this.
Apr 26, 2010 | 1988 Honda Civic 2 Door
1995 honda accord car stereo wiring. Factory stereo stollen, all I got are the stripped wires. Which cable is what?
1995 Honda Accord Stereo Wiring Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Jul 11, 2009 | 1995 Honda Accord
Lost the owners man, and need to hook up my Clarion VRX 485 VD
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
thats the radio here's the diagram for your car
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
pls rate people arnt rating hope this helps
Mar 18, 2009 | Clarion VRX485VD Car DVD Player
How to hook up my stereo
I hqave taken the time to look this up, please take a few seconds rate the solution, thanks.
Jan 06, 2009 | 1995 Honda Civic
I need a diagram for the radio to install my new system please, just need to know what the wire colors are so i dont have to spend 2 hours of test to find them myself. I will find them but if you can let...
For 2008 Honda Civic, it would be as shown below. For all other years, you may want to try looking for your specific year here where the information was originally posted.
2008 Honda Civic Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: Violet
Car Stereo Dimmer Wire: Red
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Light Blue
Car Stereo Amplifier Location: Located in the front of the center console under the center of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Light Green
Left Front Speaker Negative Wire (-): Pink
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Orange
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 31, 2008 | Honda Civic Cars & Trucks
Car Audio & Video Logo
667 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
