Question about Tomtom GO GPS Receiver
There is no sound and the sound is not muted and the volume is high as it will go.
    Champion:
  • 243 Answers
Hi, when you go to tomtom.com you can select support. then you can search for sound. they will tell you what to do and mostly this works fine. good luck.
Posted on Feb 16, 2010
How do I get sound even if volume is as high as it goes?
Jill, it help if you list the make and model of the cell phone. For instance on my Samsung S3 I can have the volume at high but if I have the mute button engage from the gear/setup it overrides my volume.
Jan 03, 2015 | Cell Phones
No sound
ight click my computer in the desktop and click properties then hardware then device manager then expand the sound vedio and game controller if you find a yellow question mark on it reinstall the driver if there is no yellow question mark go to the taskbat and right click the speaker icon then click open the volume control and look if the control volume is muted if muted remove them and move the slide to high
Feb 25, 2011 | Compaq Audio card Sound Card
Yes sound problem pls helo me now
From the Taskbar located at the bottom of your computer click once on the "Volume" icon.
Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
Right click on the "Volume" icon.
Select "Open Volume Control."
Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW Synth (short for synthesizer), CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
Right click on the "Volume Control" icon.
5
Select "Sounds and Audio Devices Properties."
Under the "Volume" tab, slide the "Device Volume" indicator to High.
6
Under the "Speaker Settings," click on "Speaker Volume."
Slide the "Left" and "Right" volume indicators to "High."
7
Click "OK." If this does not fix your sound issue, proceed to step 8.
8
Go to the "Hardware" tab and select the "Driver" tab.
9
Make sure you are connected to the Internet and then, Click on "Update Driver."
10
After the driver has been updated, Click "OK."
11
Exit.
Thanks.
Oct 10, 2010 | Computers & Internet
No any sound from the pc
Step 1
From the Task bar located at the bottom of your computer click once on the "Volume" icon.
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Click "OK." If this does not fix your sound issue, proceed to step 12.
Step 12
Step 13
Step 14
Step 15
Step 16
Step 17
Exit.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 01, 2010 | Intel DG31PR Motherboard
I cant get any sound on my computer. it is telling meno audio output device installed. and is pluged in
Please just follow the steps to fix the problem
  1. Step 1 From the Task bar located at the bottom of your computer click once on the "Volume" icon.
  2. Step 2 Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
  3. Step 3 Right click on the "Volume" icon.
  4. Step 4 Select "Open Volume Control."
  5. Step 5 Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW synthesizer, CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
  6. Step 6 Right click on the "Volume Control" icon.
  7. Step 7 Select "Sounds and Audio Devices Properties."
  8. Step 8 Under the "Volume" tab, slide the "Device Volume" indicator to High.
  9. Step 9 Under the "Speaker Settings," click on "Speaker Volume."
  10. Step 10 Slide the "Left" and "Right" volume indicators to "High."
  11. Step 11 Click "OK." If this does not fix your sound issue, proceed to step 12.
  12. Step 12 Right click on the "Volume Control" icon.
  13. Step 13 Select "Sounds and Audio Devices Properties."
  14. Step 14 Go to the "Hardware" tab and select the "Driver" tab.
  15. Step 15 Make sure you are connected to the Internet and then, Click on "Update Driver."
  16. Step 16 After the driver has been updated, Click "OK."
  17. Step 17 Exit.
Jul 31, 2010 | E-Machines eMachines Desktop PC
No sound on 17 inch LCD Monitor , Model LCm 17v2
Does the monitor have speakers?
Are they active (check that in the menu)?
Is their volume high enough (or it could be muted)?
Are the audio cables plugged in firmly both in the monitor and pc connectors?
Are they recognized as connected by the pc (check that in the Control Panel / Sounds or in the audio device config window)?
Is the pc volume high enough (or muted)?
Nov 25, 2009 | Computers & Internet
My windows media player has no sound,ya the volume
Assuming you did not get a device error while attempting to play there is a sound device thing in control pannel open it and tell it to place a sound icon in the taskbar once the icon is in the taskbar double click it and make sure all volumes are on high and make sure none are checked mute. If this does not work for you you may have a more serious problem and will need to repost.
Nov 24, 2009 | Microsoft Windows XP Home Edition
No sound in windows XP to my laptop.
A couple of things to check. First I will start with the obvious, is the volume turned up? Next you need to check that the system sound is turned on. Click on Start>settings>control panel. Then double click on Sounds and Audio Devices. On the first screen make sure there is NO check in the box next to Mute and that the slider under device volume it at high. Click the advanced button and make sure nothing is muted here and all sliders are at the top. Back at the main screen click speaker volume and make sure those sliders are on high. Finally click on the Sounds tab and make sure the Sound Scheme is set to something other than no sounds.
Mar 27, 2009 | Toshiba Satellite A135-S2276 Notebook
Samsung L100 Digital Camera, Muting my zoom??
hello to you.
that is just normal when you zoom the camera
and after you zoom the sound will be back
so dont zoom in and out always so that all the sound will be perfect..
if you want a nice volume just set it to medium not too high so that the audio will not be ruin.
and if you want some max volume just plug it to the t.v.
and set it to low volume in the camera so that it will not broke
the t.v. will give you the high volume ok...
Jan 09, 2009 | Samsung L100 Digital Camera
Volume
Did it stop working or has it ever worked before?
Make sure there is a cable running from your computer to the monitor's integrated speakers. It should go from a green 3.5mm output jack at the back of the computer to one the same size in the back of the monitor. If the cable is there and still no sound, double check the connection, make sure they are plugged in securely at both ends. Be sure that headphones are not plugged into the computer at the same time or audio will only come out through the headphones.
Make sure the audio is not muted. There is a mute in possibly 3 places. One spot is the application audio: if you're trying to play from Windows Media Player, make sure the audio is not muted near the slider and that the volume is loud enough to hear.
Second place is the system volume. In the Control Panel, Audio (Start menu, Settings, Control Panel, Audio component) you can check the volume and mute of the system volume.
Third location is the monitor speakers. There may be a way in the monitor's menu to adjust the volume for the speakers. Make sure it is high enough to be audible.
If all of those are unmuted and high, you might try replacing the audio cable. Also reboot the computer with the audio cable plugged in where it should be. (Sometimes high-def digital audio can be quirky). Next try plugging in a pair of headphones into the front of the computer and see if you're getting any sound through there.
Those steps should help you diagnose the problem. If not, just post back with what you found out through these steps.
Nov 25, 2008 | HP Compaq WF1907 Monitor
Tomtom GO GPS Receiver Logo
61 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
