Question about GE Washing Machines
I have a G.E profile washer, model WPRB9220DWW . 4 yrs old and it recently has been coming on by its own and girgling sounds as if the pump is sensing the need to. when it does this, no lights come on and can only stop it by unplugging. sometimes it spins and drains fine but at times leaves standing water in tub. could there be a sensor telling the pump to do this? its all digital l.e.d. controls ?????
  • 129 Answers
Sounds like the control board has shorted out. There is only a 1 year warranty on this unit.The cost of the new control and touch pad are.
Part # wh12x10316 $ 295.00 #wh42x10503 $ 60.00 With this cost and no warranty it does not seem like a good idea to put money into this unit. You can purchase a good quality washer for around $ 500.00.
Posted on Feb 06, 2010
Dark particles all over clothes once washed. I cleaned the washer, ran a tide washer cleaner through, checked and cleaned the screen filters that hot and cold hoses pump water through. Is there anything...
sounds like you may need to check your hot water heater for deterioration. since you have done all that you need to check your water supply. a water heater can deteriorate on the inside for a time before you will notice it. good luck
Sep 06, 2011 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
My Kenmore 800 series washer is leaking water all over the floor and i can't find where its coming from. It only leaks when its on and running. I tried to take the back of it off to see where it was coming...
Some of theses models have a tendency of leaking out the side of the pump housing. In this case you will need to replace it. Here is a link to help disassemble and acess the pump.
Disassembling a whirlpool style washer
Oct 13, 2010 | Kenmore 22422 Top Load Washer
GE Profile washing machine that will not drain
just remember your machine always has water in it so when you do get to the pump and pull of the hose to the pump alot of water is going to come out. some washer have no bottom so tilt it over and look the pump will be transparent so you should be able to see if anything is inside the pump. have a shop vac ready.(all the water)
Apr 04, 2010 | Washing Machines
Dish washer 3 1/2 yrs old making a growling/vibrating sound.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 28, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My washer keeps giving the message that the washer wont drain. Check the lines for kinks, etc. I have removed the back of the washer, checked the pump and all of the drain hoses, there is no blockage. The...
you may want to look at that pump again
for that model is rated at 8.5 ft
so it should be moving that water right along
when you have the pump hoses off put the unit in drain and watch the impella, it is quite possible stripped.
Oct 15, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
1997 dodge stratus girgling sound
Check the fluid level after the vehicle has cooled down to see if it is low....even if you had items fixed.
Mar 01, 2009 | 1997 Dodge Stratus
Leaking
Flooding like that usually means a bad drain hose or bad hose connection either at the bottom of the basket or at the drain pump. Need to check both.
Apr 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
326 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
