Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
I have an mci alien 50cc scooter the oil light remains on even though the oil is full
  • 425 Answers
Three things will cause this:
1: The sensor is cactus
2: The sensor is blocked (with gunk) and can not function.
3: There is no oil pressure to make it function.
2 is easy, you just take it out and clean it, if the problem is rectified then all is well. If not, you replace it, if the problem is rectified then all is well. If not you take it to a reputable bike mechanic, or get a manual and get it fixed. But I did not think that small bikes used oil pumps, I was of the opinion they used the oil spash technique. Could be wrong??????
Posted on Feb 06, 2010
How to change my oil in 2014 typhoon 50cc
Hi, Connie for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
What Type of Engine Oil Should Use in My Scooter
How to change the motor oil in your scooter 50cc
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Chinese Scooter Parts Diagrams
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 20, 2017 | 2014 Piaggio Typhoon 50
How to refuel a sym jolie 50cc scooter, do you mix oil into the petrol tank, or do you fill the oil and fuel seperatley or does it mix it itself????
Pretty much all are normal petrol in the fuel tank and the oil is on another tank. The oil is mixed as it enters the inlet manifold.
Your manual is here. Section 2-3
ScooterCommunity
Nov 06, 2016 | Sym Motorcycles
I have a 50cc tao tao scooter. How do I disassemble the piston rings, the oil is blowing out cause the valve is sticking?
Hi, Lisa your scooter has a GY6 engine that's all that matters for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Tao Tao, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Top End GY6 Replacement video 1
50cc to Big Bore 80cc Scooter Rebuild upgrade Kit How to do it Racing...
TaoTao 50cc Scooter Owners Manual
Jun 01, 2016 | Motorcycles
Runs but not idling
The idle screw is normally found on the carburetor and is a screw with a spring, close to where the throttle cable enters the carb.
Jan 28, 2014 | Quad Cycling
Oil in Derbi 2002 atlantis 50cc scooter
CLEAN CARB TO MUCH OIL IS BURNING IN ENGIHENCE GAS/OIL MIX CHECK FILTER/LINES OF GAS AND CHECK PET COCK ETC
Jun 23, 2013 | 2004 Petronas FP1
Oil in 2002 Derbi Atlantis 50cc Scooter?
DRAIN OLD OIL CHECK LINE/FILTERS REPLACE AS NEEDED ADD NEW OIL.
Jun 23, 2013 | Derbi Motorcycles
I have a mci alien i bought it new it has full tank of oil but it seems like no oil is pumping into the engine and now it runs for about 2 mins then just completly losses power what is wrong
If your oil tank is full you may have problems with the oil pump or have an obstructed or collapsed oil line. In either case don't use it until you find the reason that you have no oil circulation because it will cause damage to the engine.
Jun 26, 2011 | 2004 Mondial RZ Nuda
Oil light
the oil sender [switch] is plugged into the oil tank check the wires are still plugged into wireing lume if so the switch will more than likely to be at fualt
Feb 05, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Lifan metro scooter wont turn off
have a look at the cdi plug ...one of the terminal in the plug cluster may have a broken wire or not making good connection with the cdi.
Jan 13, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
464 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
