E-machine T3085 video card problem?
My monitor had been flashing on and off past few weeks. Yesterday shut down completly. Won't even power up. Bought new monitor today hooked it up and it says no signal and then it goes into power save. Tried new monitor on another computer with no problem. Is my video card shot? Is this something I can purchase on my own and install?
    Genius:
  • 3,587 Answers
Yeppers..that video card sounds bad..open up machine first, and make certain it's still seated properly.
got backup for that E machine?
Posted on Feb 21, 2008
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Video worked fine till the power black out last week. The machine was off when the power came back on. I tried a different monitor that I know works, I re-seated the ram, and bought a new video card but...
hello
You should try first the onboard VGA output of your motherboard to be sure if the Video Card is damaged. And to be sure f your motherboard is working. Keep on touch
Aug 28, 2011 | Computers & Internet
Monitor shut down or system freeze
check the wattage rating for you card  and the output rating for you power supply should be about 20% higher that the card
Jan 04, 2010 | ATI RADEON Graphic Card
Yup same problem here..
I give you some possibilities.
1. Could be dirty contact for your memory card, try to take out the battery and no power supply attached and shut it down completely, then clean the memory edge connector with a clean soft eraser. And be sure to drain your hands with static. Then reseat it back into its place. Or the memory card or actually faulty using an spare ram to check it.
2. This can be also monitor problem, try using secondary monitor and run it to dual monitor.
3. There's some component giving up in your system, usually hard drive or cdrom. This cause hanging and shut off of your unit also. Try disenganging one at a time to find the fault. And boot using usb flash drive if you can.
This is my simple and first way fix. goodluck
Jul 07, 2009 | Toshiba Satellite A105-S4334 Notebook
Locks up but usuallyshuts down
i would try getting a new power supply. since you got a new video card, you will need a higher powered one, like 350 to 450 watts
Nov 28, 2008 | E-Machines T3085 PC Desktop
Samsung 225bw display with NO VIDEO and flashing power button
A flashing power light and no picture is a sure indication of a shorted power supply board. There are parts called capacitors that fail and this causes the power supply to continuously shut down and restart over and over, hence the power light flashing. If you can do a little soldering then you can repair the unit. Here is a link to a service guide showing how to dis-assemble the monitor and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
I hope this helps, if so please ratre my solution.
BuddyMc
Nov 22, 2008 | Samsung 225BW Monitor
Computers & Internet Logo
139 people viewed this question
Alun Cox
David Payne
David Payne
