Question about Nintendo 2000 Wii Points Card for Wii
Will not register on Wii console internet is up and running
    Scholar:
  • 121 Answers
Is your console's region set the same as your card's region?
Posted on Jun 04, 2010
Have connected wii to cable via cisco asa 5505 box. getting error code 52020. have restarted comcast modem to no effect.
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
Aug 09, 2011 | Nintendo Wii Console
I'm trying to connect my Wii to the Internet. I currently do not have a wifi connection but I have the adapter that connects to the internet. I have already changed the connection on the Internet...
you can try this step on how to connect your wii console on internet...
if this help you please rate me thank you sir.....
Jul 05, 2011 | Nintendo Wii Console
How do i connect to netflix
Hi there. Follow these steps.
1. Have an internet connection, wireless or wired.
2. Go to the Wii Shop Channel.
3. Search for Netflix and download the application.
4. Go back to Wii home and install Netflix
And there you go, follow the onscreen instructions, register and enjoy.
Please rate and comment, thank you.
Apr 16, 2011 | Nintendo Wii Console
When I try to connect to the Internet it keeps giving me a error code 52030
Error 52030 is a security settings error built into the Wii. This means the Wii is either incompatible with your router's security settings or your router isn't able to assign the Wii an IP address (which means it can't register it onto your network).
Nintendo has provided official information for solving this problem here: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
Mar 12, 2011 | Nintendo Wii Console
My wii won' t register
You should first check to see if your internet connection on the Wii is up and running. Next just double check through all of the steps that your doing everything correctly. Good Luck!
Mar 03, 2011 | Nintendo Wii Console
Netflix wont play on my wii right now, but does work on my pc, so it's not a nerwork problem. any suggestions?
There are a few things that could be preventing this from working. First, if I recall correctly Wii still requires the special Netflix disk to play any movies, so make sure you have that and it's in the console. If you don't have it, log onto Netflix from your computer and you can easily have it sent to you. It's free, so no worries there.
Now if you have the disk, and you still can't get Netflix to work, make sure that your Wii is registered on Netflix. Again, this can be done from the Netflix website. To check what you have registered to your account just;
Log on to Netflix.
Click "Your account and Help" at the top right of your browser.
Scroll down to "WATCHING INSTANTLY ON YOUR TV OR COMPUTER"
Click on "Manage Netflix ready devices and computer"
Now you'll see a list of devices that are registered to your Netflix account. Make sure your Wii is on there, and if not, then you'll have to re-register your Wii in order for it to work.
If none of this works, then double check your internet connection and be sure your Wii is properly connecting to the internet.
Please leave a comment or rating letting me know if this was helpful or not, feedback is always welcome. Good luck with your Wii, and Netflix.
Dec 23, 2010 | Nintendo Wii Console
How do I connect to another WII on the internet
you have to register each other by exchanging friend codes (you both have to have each others friend code) you do this by on the wii menu you click the icon on the bottom left ahnd coner and got to address book and add a contact
Nov 13, 2009 | Nintendo Wii Console
Connection Comcast router to wii
Error Code: 52021 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
Mar 13, 2009 | Nintendo Wii Console
Error code 109144 when try to connect to internet via wii console
Error Code: 109144 There was a problem registering the console to the WiiConnect24 service. What to do:
  • If you have multiple routers and/or modems, try to connect to no more than one router and one modem try connecting from another location.
  • If you are using only one modem or router, something on your network or from your Internet Service Provider is blocking the connection. You may need to contact your service provider for more information.
  • If you do not have the ability to connect from another location (such as a friend's house), please call 1-800-255-3700 so that we may discuss available options.
Feb 01, 2009 | Nintendo Wii Console
Nintendo 2000 Wii Points Card for  Wii Logo
51 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
