Question about Cell Phones
Don't know my bluethooths security code to pair it with my new cell phone.
What is the make and model of your bluetooth and the make and model of your cell phone?
Posted on Feb 05, 2010
How do I pair my phone to the bluethooth on car radio
Depends on the car stereo.
Although generally you would need to change the "channel" to Blue Tooth, and make sure Blue Tooth is turned on on your phone. Press the appropriate button (in mose cases if a new BT device is detected you would push the volume knob). Once the pair sequence has started, a pass code should be displayed. Verify the pass code on your phone and press the volume knob again to pair.
What is the make and model of the radio? This will help us find more specific instructions for you. Thanks!
Apr 06, 2015 | Cell Phones
Why can't I connect to the bluethooth that is stored in my phone?
What are you trying to connect with bluetooth? You need at least 2 devices that you have to connect by a process called 'pairing', where at least one of them is 'visible' (this means it can be discovered by any bluetooth devices searching for it) and then you must start pairing. Both devices must agree on a pass code, for example 5555 and you must put this in both devices when they ask for a pairing code.
Jul 26, 2011 | Cell Phones
I can't connect my loptop my southwings bluethooth heads because his requesting the pairing code... but i don,t know what is code... can u please help us
pairing code you usually set one one device then on the other you can input 4 numbers like 0000 and then 0000 on the other sometimes its 1234 or 12345
Mar 22, 2011 | SouthWing SH105 Bluetooth Headset
I cant pair my htc hd7 with other devices when i use my bluethooth
Turn Bluetooth on by going to Start Screen>All Applications>Settings>Bluetooth.
Once the Bluetooth has been turned on it will then be in both the searching and discoverable mode.
The device will return a list of devices it found during its search. Touch on the item that you want to connect to, enter a pass code, confirm the pass code on the other device and the pairing will be complete.
Mar 22, 2011 | HTC HD7 Cell Phone
How do I pair bluetooth from one phone to a new phone? Removing bluethooth from my old phone to another phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 12, 2010 | LG Dare VX9700 Cell Phone
How to connect by bluethooth in Lexus 350 to blackberry 8520
Take care.
Aug 30, 2010 | RIM BlackBerry Curve 8520 Smartphone
I have a handsfree bluetooth headset for nokia and i don't know how to pair it... ?
Nokia 1100 does not have bluethooth .
you can use blue thooth if both phones has bluethooth option
Jan 13, 2010 | Nokia 1100
I try to pair S9 Motorola bluethooth headset
well reset both phones and try again...if still wont work then it's blutooth version problem can't do any thing
Nov 19, 2009 | Nokia 5800 XpressMusic Smartphone
Not paired, Motorola Blue tooth H300 to iPhone 3G S
hi
when the bluetooth id discovered it has to be registered with the default code of 0000 over the handset to be paired
hope this helped
cheers
Jul 07, 2009 | Dual Electronics CECT P168 Cellular Phone
Nexxus bluetooth car kit
To pair you must first turn bluethooth feature ON on Sony phone. This usually has an indication on lcd display when it turned ON (it looks like a headphone sign) the you must turn visibility of your phone ON making it ready to be paired. Following instruction that came with bluetooth kit put bluetooth in pairing mode when its in paring mode led lights will rapidly fash. At this point you phone should pick up bluetooth if it doesn't then do a search for bluetooth devices with your phone and it will find the bluetooth (make sure its in pairing mode) It will display the bluetooth type and model number. It also may ask for security code if it does it 0000 set by default. Then pairing should be complete just save and you should be good to go. Good luck and thanks for using fix ya
Jan 28, 2009 | Cell Phones
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
