Question about Westinghouse L2046NV Monitor
Have a 2year old L2046NV LCD Monitor on my HP pavilion a814x Desktop. Worked great till a few months ago when it started giving "out of range" message ONLY when trying to startup iWin Jewel Quest game. I also still have sound, no video. I had been playing this game on that monitor for over a year. Updated all drivers I could for all components. Res and refresh are same for monitor and video card. Monitor still works great for all other apps with that XP SP3 Home Edition computer. Didn't notice any direct connection between new installed or removed apps/updates when the problem started. I did reconnect previous monitor tonight. I can play the game, no problems. Any ideas?
jonb3838
  • 237 Answers
SOURCE: westinghouse monitor displays big red OUT OF RANGE
your didplay setting is not supported by the monitor or your drivers for your vga need to be updated
Posted on Apr 30, 2009
  • 1684 Answers
SOURCE: I have a Westinghouse L2046NV
You have a monitor with a very common problem, a blown power supply. The heat that builds up in the monitor case causes parts called capacitors to overheat and blow out. When you turn on the monitor they try to hold a charge and show a picture but loose the charge fast and the picture goes dark. If you can solder then you should be able to do the repair yourself. Go to our web site at:
www.ccl-la.com/badcaps.htm and look at the pictures of what the blown capacitors look like. Now open the bad of your monitor and replace any that look like the pictures. The values that you need to purchase will be marked on the sides of the blown ones but will be values like 220uf, 470uf, 1000uf and then a voltage rating. Be sure to get high temp (105c) replacements or you will have to do the repair again in a month or two. The parts at Radio Shack will not do there are several places on the internet to order them from or we can supply you with them. When you install the new ones just insert the caps with the polarity stripe going the same direction as the old ones come out. If you have any questions just let me know. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Oct 04, 2009
Geekman
  • 32281 Answers
SOURCE: I need a parts for a Westinghouse LCD Monitor.
What parts do you need?
You can get service, parts and DIY info from LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Posted on Oct 21, 2009
  • 630 Answers
SOURCE: I have a problem with my monitor not coming back
It could be a cable problem but more likely to be in the power saving settings on either the monitor setup or the computer. Remember when you plug in a different monitor windows knows about it and adjusts the settings to suit. It may be that windows is using the incorrect wakeup signal for that monitor. check you have the correct driver installed.
Posted on Oct 24, 2009
  • 78 Answers
SOURCE: I have a Westinghouse LCM-19v5
in the safe mode you have to change the resoulution and the frequency to 60 hz you can get it by fright click on the screen and then choose properties and then choose settings and adjust the resolution to 1280 to 800 and then choose advanced then choose monitor then choose the frecuancy to 60 hz ok and apply ok and insa every thing will be ok conntact me for more if you still haveing the same problem
Posted on Nov 15, 2009
HP Pavilion a120n was working great until a few months ago when it appeared that the monitor went out. I tried two different monitors and get NO VIDEO OUTPUT messages on the screen. All the connections are...
Do u have a graphics card in the pc? If you have then disconnect the video cable from that and connect the video cable with the default vga port of the motherboard and check. if there is no graphics card then the integrated graphics card of the motherboard is damaged. that means motherboard is needed to be replaced.
Feb 17, 2011 | HP Pavilion a1220n (A1220NED904AA) PC...
Using Windows 7, relatively new HP Pavilion dv7. About a week ago a Memory Dump blue screen started appearing spontaneously, would stay on for only a very few seconds, then restart the computer. There...
hi
memory dump is the result of bad memory module (RAM).. remove the ram modules, look at them, make sure they are same make and part. different manufactures can often cause memory fault in a system
if that's the case, replace the memory modules . you can go to the link below and select the model you have, go to KEYWORD selection, and select MEMORY DIMM, it will then give you the part number you need to replace .
if you need more help, please don't hesitate to issue 4 thumbs and i will give you further details and cost of the modules. you can easily purchase at a link i will issue at that time.
http://h20141.www2.hp.com/Hpparts/Search_Multi_Product.aspx?mscssid=49A90DD091EA4D89B2FC957BD1525074&SearchCriteria=dv7t
please issue 4 thumbs up
Jan 07, 2011 | HP Pavilion dv7t PC Notebook
I do have a question, i was using old starlogic monitor (actually i have 2 of them, for now, 1st one is old, the second one is 'twin' ) i bought a pc emachine couple of months ago in april. any way. the...
What I have understood is that the resolution of the Windows is way too high for the monitor. Remedy. reboot in safe mode and when booted, right click on the desktop and select Properties->Settings. It will show you the display settings including the resolution. Reduce the resolution and keep the highest that the monitor can take. You may have to reboot a number of times. All the best.
Aug 22, 2010 | Star Logic 17" LCD Monitor
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
New hp computer not communicating with Insignia LCD TV monitor
before starting keep press f8. then choose safe mode then if you are in ur desktop try to ressetting your display 800x600 then finally done......
Feb 13, 2010 | Computers & Internet
External monitor cannot stop moving
You need to right click on the desktop, select properties and then settings.  Change the resolution to be correct (or smaller) than that of your monitor.
I suggest you start with 800x600 and then work your way up till it starts scrolling again.  then go down 1 resolution.
Jan 08, 2009 | HP Pavilion F50 17" Flat Panel LCD Monitor
My auto start will not work
Check the properties for the drive make sure autoplay is enabled.
May 23, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
Inaccurate yardages
Hmm your Bushnell has one year warranty send it back to company under warranty for repair.
Nov 12, 2007 | Bushnell Elite 20-5100 Rangefinder
HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
Oct 29, 2007 | HP Pavilion F1703 17" LCD Monitor
Westinghouse L2046NV Monitor Logo
129 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
