Question about Hotpoint HSS25GFP Side by Side Refrigerator
No water from dispenser. I replaced the funnel assembly and the mounting bracket and I am not getting any water from the dispenser. I had thought the dispenser funnel was not working because one if the tabs on the funnel was broken.
I found that my ice tray had a layer of ice built up in the bottom. I cleaned that all out and later in the evening my water dispenser started working again. The only thing I can figure is that the water tube froze up and once the tray was cleaned out it allowed the tube to defrost.
Hope that helps.
Posted on Feb 08, 2010
  • 56 Answers
Check to make sure the fill line inside the door is not frozen. also check for water coming out of the valve. also could be your water filter.
Posted on Feb 07, 2010
How to install samsung Part Number DC31-00054A (AP4202690)
1. Unplug the washer. 2. Unscrew the 2 screws at the top back of the washer that secures the top of washer pane, slide it back and lift off, remove and set aside. 3. Pull out the dispenser tray and depress the tab at the back to full remove. 4. Remove the dispenser mounting screws, slide the dispenser back. 5. Carefully pull the control panel off from the top, disconnect the two wire harnesses and set the control panel aside. 6. Use needle nose pliers to remove the retaining wire and spring from the door boot seal, pull the seal away from the lip of the front panel. 7. Remove the 3 door mounting screws to release door latch assembly from the front panel. 8. Open and detach the filter access door and release the drain tube from the retaining tab. 9. Remove the screws inside the filter housing securing the front panel. 10. Carefully lift the front of the washer up and support it. 11. You can now remove the screws at the bottom securing the front panel(if your has these, mine were missing). 12. Now is also a good time to detach the pump assembly wire retainer from the base(small white plastic tab sticking downward). 13. Remove the support and gently lower the washer back down. 14. Remove the mounting screws on top of the front panel. 15. Now, use a flat head screw driver to depress the locking tabs to release the front panel from the frame. 16. Detach the recirculation hose from the retaining brackets on the inside of the front panel and set the panel aside. 17. Uncap the drain tube, and drain the excess water, then recap the tube. 18. Release the retaining clamps securing the hoses to the pump assembly and slide the hoses off.(be prepared for some water to spill). 19. Remove the two screws securing the pump assembly to the mounting bracket. 20. Now, push the assembly back to release it from the base. 21. Next, detach the drain pump cover(top white plastic cover) and disconnect the wires, now remove the 3 mounting screws and pull off the old pump. 21. Install the new drain pump by properly aligning it on the assembly. 22. Replace the mounting screws to secure. 23. Connect the wires to the new pump and snap on the cover. 24. Position the pump assembly into the cabinet base by inserting the mounting tab into the slots in the base, then push forward. 25. Replace the screws to secure the assembly to the mounting bracket. 26. Snap the wire retainer into the base. 27. Reattach all of the hoses to the appropriate ports on the assembly and position the retaining clamps to secure. 28. Replace the front panel, by aligning the slots in the panel with the tabs on the base. 29. Secure the recirculation hose in the retaining brackets, making sure the door latch is inside the cabinet and snap the top half the panel into position. 30. Replace the screws on top. 31. Lift and support the washer, then replace the screws on bottom. 32. Remove the support and lower the washer. 33. Replace the 2 screws in the filter housing. 34. Secure the drain tube under the retaining tab. 35. Reattach the filter access door and snap it closed. 36. Now, realign the door latch assembly in the front panel, and replace the mounting screws. 37. Align the boot seal on the front lip of the panel. 38. Replace the retaining wire and spring to secure. 39. Replace the control panel, by first reconnecting the wire harnesses. 40. Now, insert the control panel tabs into the slots into the trim and snap the top half of the panel into place. 41. Reposition the dispenser and replace the mounting screws. 42. Slide the tray into place. 43. Reposition the top panel by aligning the edge of the panel with tabs on the support bracket, then push forward.
44. Replace the screws at the back. 45. Plug the power cord back in. Your done!
Your washer should be ready to use now!!! Good Job!
You should find this video useful, even if it is for a different model washer, it is what I used as a reference. Drain Pump Replacement part DC31 00054D Samsung Washer Repair
Sep 06, 2014 | Samsung WF448AAP Front Load Washer
What can be done to fix this without having to change whole unit?. - "water from nozzle from door dispenser assembly 4200960 of subzero s690 is spewing out on to kitchen floor instead of vertically down...
Remove the dispense and reinstall the waterline back into dispenser housing. Make sure the this is the only source of the water issue you have. The tube can slid back into the dispenser and cause the water to run behind the assembly. this is rare thought for the only way this could happen is the dispenser was replaced and the hose was not reinstalled correctly.
Good Luck
Sep 19, 2013 | APW Wyott SubZero Refrigerator Freezer...
Can water/ice dispenser be fixed without replacing door
Go to www.repairclinic.com and enter GSS25SGRSS. With luck, you will be presented with a list of common replacement parts/assemblies and will be able to determine whether the dispenser is available as a separate assembly.
Nov 08, 2017 | GE GSS25SGRSS Side by Side Refrigerator
How do i replace ps 652226 ice funnel ge ziss480drbs
carefully removed the trim from around the dispenser area by gently prying the trim off careful not to brake it. then freed the catches in the top of the electronic card. I leaned the card forward and disconnected the electrical connections, then removed the card. I removed the four screws holding the shield to the door and removed the shield. Then I removed the funnel from the shield and removed the spring from the old funnel and placed it on the new one. I removed the light and socket from the old shield and installed the in the new one, then installed the new funnel on the new shield, used the four screws to install the assembly on the door and replaced the trim piece. Here's a DIAGRAM to help.
Mar 05, 2011 | Refrigerators
How do you change a pump on a Samsung WF448AAP washer? Need to get in from the back?
Dec 07, 2010 | Samsung WF448AAP Front Load Washer
How to replace driver's side brake light 2003 Jetta wagen
just a thought,has someone put double sided tape on the mounting bracket to stop vibration.....i would....
May 24, 2010 | 2003 Volkswagen Jetta TDI
The fabric softner dispenser does not release the liquid softner
The fabric softener solenoid valve is faulty and must be replaced. It is sold as an assembly with the bleach solenoid valve with part number 997846. You need to remove the front panel to lift the top panel to inspect or replace the valves.
Front panel removal procedure:
  1. Unplug the machine.
  2. Turn off the water supply.
  3. Open the door and remove it by removing the screws on the hinges holding it.
  4. Remove the remaining two screws on the opposite side along the inside lip of the door opening.
  5. Press in on the outer upper edges of the front panel posts then twist it inward to release it from the clips on the face of the cabinet.
  6. Tilt the top of the front panel away from the washer and remove it.
  7. Remove the four screws holding the dispenser bezel to the top of the top panel.
  8. Remove the 5/16" hex head screws securing the two hold down brackets on the top panel.
  9. Swing the hold down brackets to the outside to unhook it from the slot in the top panel lip.
  10. Lift the front of the top panel and tilt it toward the rear of the machine.
  11. The dispenser valve assembly is the one on right of the water inlet valve assembly where the water supply line is attached to. The fabric softener dispenser valve is the one on the right most.
  12. Clean the terminals and the connector of the fabric softener dispenser valve.
  13. Grab a multimeter and check the resistance between its terminals. The resistance should be between 500 to 1000 ohms. If it reads open, replace the dispenser valve assembly.
  14. Remove the wire harness connections to the valve solenoids.
  15. Loosen and remove the hose clamps on the hoses.
  16. Loosen the valve mounting screws by turning it at least three full turns.
  17. Slide the valve assembly to the left and remove it from the bracket.
  18. Place a towel below the valve and remove the hoses.
  19. Install the new dispenser valve assembly in reverse order.
  20. Install the top panel, dispenser bezel, front panel and the door in reverse order of the removal procedure.
Jan 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do you replace the dispenser funnel on an LG Refridgerator model LRSC-26923
funnel itself squeeze in on sides to release tabs. so many tabs broke a redesign was made 5-30-2005 , have to replace frame bracket and funnell. models after tant had new design. part number from exploded view: 3016JA2002C funnel 278d location number exp. view
3210JA0006S frame 278b location '"" '' ""
Sep 10, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG refrigerator - Need help replacing a part in the door.
How to install part ac110-115v for lg refrigerator
Jul 10, 2009 | LG Refrigerators
Ice and Water Dispenser Funnel
This diagram may help some.. should be a molding thats goes around outside of dispenser.. should be able to pop off and get at screws u need to get at...to remove and get at what u need too
http://www.partselect.com/Schematics/GE/00116598i01.gif
Nov 01, 2007 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
221 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
