Question about Dryers
My Whirlpool dryer seems to get warm enough judging by the warm exhaust tube but the clothes don't get dry just damp.I have tried on different settings but manual seems to work best but even then not very well.
    Sergeant:
    Champion:
  • 263 Answers
Clogged vent most likely.
Dryer repair in orange county, ca
Posted on Feb 05, 2010
Testimonial: "Cleaned vent and it seemed to be working much better. Thanks."
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Dryer gets hot, but stays damp inside and clothes don't dry. I removed a birds nest from the outer end of the vent, and there is plenty of hot steamy air coming through, but still having this problem....
The vent is probably still stopped up. You are going to have to pull the dryer out and disconnect the 4" vent hose from the back and inspect the vent all the way through.
May 18, 2011 | Dryers
NOT DRYING PROPERLY CLOTHES STILL WET AFTER 70MIN DRYING TIME CLOTHES ARE WARM DAMP
First check that the exhaust duct is clean, has no kinks and that the air flow is unrestricted. Sometimes water will condense inside the exhaust hose and not allow the damp air to flow.
I assume that the dryer works quietly, if not, then probably the blower fan needs replacing.
Feb 20, 2011 | Amana Dryers
My dryer is not heating the air clothes are rolling and air seems to be blowing but the clothes are damp when cycle ends and they are not warm. what do i need to fix this?
if the clothes are damp then I would disconnect the vent tube, and dry a load of clothes. If they are dry then the vent needs to cleaned. Hope this helps Tim
Feb 06, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Dryer seems to run OK and it heats up but the clothes are damp. Even after running them thru two or three times. Exhaust is clean and clear but there is not much lint build up either.
I know you say the exhaust is clear but please check again.start unit and go outside to vent and check for good warm airflow..80% of clothes drying concerns are related to restricted air flow not helping to get rid of the moisture in the clothes
Aug 10, 2010 | Dryers
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
My Whirlpool Duet gas dryer doesn't seem to be drying my clothes. The clothes are staying damp.
If the load is extremely large or heavy it may require more time. If you are using the auto cycle and the clothes are not drying try setting the sensor to a "more dry" setting. Make sure the lint filter is clean and that the exhaust vent duct is not clogged. Check all the way to the outlet. If all is clear then the thermostat may need to be replaced if it is not calling for heat as often as it should. Also check to make sure there is air flow from the vent. If not then the fan/blower may be broken or disconnected from the motor shaft.
Dec 22, 2009 | Whirlpool Dryers
My Whirlpool dryer suddenly leaves clothes damp
Be sure to check the thermostats...they can cause this problem
Sep 22, 2009 | Whirlpool Dryers
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
