Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Oven won't heat up
When I turn the large oven on, it barely heats up, perhaps getting to 180 F. Breaker is on. Oven is plugged in. Small oven works fine.
I cleaned the oven recently, but I think it didn't really clean properly. There was no ash in the bottom.
Please help fast. WE have a chef from Italy cooking in the kitchen for a benefit tomorrow.
Thank you.
    Novelist:
  • 128 Answers
Are the burners lighting properly. checked for clogged orifices in the burner jet. if electric check fuses for igniter and see if spark is present with gas off of course. hope this will help
Posted on Feb 05, 2010
Blodgette issue convection oven 208/240 60Hz haveing issue with plug over heating what size breaker should i use 20 or 30amp. Wiring is on a line seprated. What gage wire should i use.
Check the manufacturer's website for the manual. If the cable is getting hot, the wire gauge is too small. 30A needs a 10G wire, 40A needs a 8G wire. Again, check the manufacturer's website for the manual. If you are not sure, call an electrician. Be safe!
Dec 21, 2016 | Ovens
Oven will not pre-heat properly
you might want to check where the thermometer is located on older models it can be knocked out of position perhaps to close to the roof of the oven which gives false heat reading
May 01, 2015 | Kenmore Kitchen Ranges
Oven won't heat
major electrical problem. call a repair man asap!
May 19, 2013 | GE Profile JT912 Electric Single Oven
Oven will not turn off and turns on, on its own
Either bake element is grounded out or control / clock is defective
Nov 03, 2017 | GE JBP90 Electric Kitchen Range
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
I have a frigidaire oven model number GLEF378CSB - won't heat up
Make sure your getting 240 volts to the unit if not it's the board...sorry. More then likely it's the board.
Jan 10, 2010 | Ovens
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Kitchen aid slide in range - oven stopped working
Wynco, first thing I'd check is whether or not you are getting the 220 volts the unit needs. Find the circuit breaker and turn it off and then back on. This should be a dual or linked breaker. The breakers do corrode and wear out and may need to be replaced.
Dec 11, 2007 | KitchenAid KESC307 Electric Kitchen Range
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
