Question about Kitchen Ranges
1 of my stove top burners has no clicking when turned on. however, if i turn on the other burner igniter at the same time i turn on the bad burner, it will light
  • 80 Answers
Your sparker module inside of the problem burner button has failed, need to replace it.
Posted on Feb 06, 2010
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
Burners turn on sometimes as does the oven but then may not turn off
Hello, when you turn on one of the burner, can you hear some clicking while you turn on one of the burners? This is an electric ignitor, and when you turn one burner on all the burner ignitor will click.
It is possible, that you are turning your burners on the stove to quick. Take a look at one of knobs and you will see ignition--low---medium---high. To get the burning ignited the knob needs to be position at the ignition site. You'll hear it click-click-click and the burner will ignite.
Now, the oven. The oven ignitor is on a time delay. You will push the bake button and across the screen will say something like this "Please set oven temperature" You'll set the oven temperature to---let say 350 degrees---. Then the screen will say "push start button" then you push the start button to turn your oven on. Now, the screen will say "pre" this means that the oven is pre-heating the oven to your desired temperature. Before all this happens there is ignitor in the oven and it has a heater on the ignitor in oven. This heater will heat up to desired temperature and once it reaches the that temperature the ignitor will ignite and the gas will turn on.
Why--one would say for this procedure. The old kitchen stoves had a very bad habit of of flash over---that is gas will built up in the over and once the pilot light ignited the gas---wussh and it blow the oven door open. These ovens would sometimes huff too.
Therefore, take your time and your biscuit will be OK
I am sorry Sandan2. I didn't finish reading your question. Never mind on what I said here.
If the burners will not shut off sometimes, then there could a gas regulator problem.
One very important question. Is your kitchen stove using Natural Gas or LPG--liquid Petroleum Gas?
If it is using either type of fuel as mention above. It is very important that you contact Appliance repair person that is certified by the state that you live in that he/she is license by the state to work with gas appliances.
I wish you luck, but it very it important that you contact a certified Technician... Also, move the stove away from the wall and look behind it. There a black gas pipe and at the end is a brass valve, Take wrench and turn the gas valve off. The gas valve will have a stainless steel flex line attached to it, and the other end is to your stove. Don't use your stove.
If those gas burners and the oven are leaking gas. There is possibility to blow you and your family with your home up. Don't use the stove, Until you have it check out...please. GB you/your family...stewbison
Sep 07, 2011 | LG LRE30755ST Kitchen Range
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
Jul 31, 2010 | Jenn-Air 30 in. CCG2423 Gas Cooktop
How do you light the oven? We turn the dial and
I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
Igniter on Wolf Stove clicks continuosly
Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
Aug 14, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter continuously clicks
I had this problem. It was caused by the burner "thinking" the flame had turned off--it was clicking because it was sparking to re-start the flame from the gas. I was able to fix it by tightening a flat, thin nut at the top of the burner.
Apr 13, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
