Question about Maytag PER5710 Performa Electric Kitchen Range
Oven control Maytag Per5710 Electric Smooth top Range
Pushing either the "bake" or "Broil" control starts the "lock" indicator to flash. Pushing any other function will cause the "lock" to go off. If the oven door is physically locked and the "clean" control pushed, the timer indicates 3:00 and the heating element in the oven will come on about 1 minute or less then shut off with the timer/clock indicating "F9". The oven will not heat at all in the bake or broil modes. The cook top appears to function normally on all burners. Have turned off power to the range for 30 seconds and restored. Smae indications as before.
  • Anonymous Apr 29, 2008
    The exact same thing is happening to my maytag oven. The power was out for a couple of hours due to a storm and it's been doing this since then. It seems like there should be a reset button or something.
  • Maine276 Jul 31, 2008
    We are having the exact same problem with the exact same stove. Did you ever find out what it was?
  • 833 Answers
SOURCE: Oven will not bake or broil
bann...why did you replace the element? It is possible that the relay or the control circuit were the problems and still are. The hi limit switch is a temperature 'box' which is designed to open the circuit in case of overheating. Rarely a problem. First, these units are 3 wire units. That means 220 volts ... two breakers. They may be part of a linked unit or separate. Turn them BOTH off and then on. Do all of your burners heat properly on high? If you have a voltage tester, you can test to see if the voltage is there. Unplug the unit. The vertical slot is neutral. Each of the other slots with the neutral should light the tester. If not, your problem is outside the stove.
Posted on Dec 12, 2007
  • 71 Answers
SOURCE: Oven will not bake, but broil works
the bake ignitor is most likley bad
Posted on Dec 24, 2008
  • 197 Answers
SOURCE: My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Posted on Sep 21, 2009
jsrock516
  • 5911 Answers
SOURCE: I keep getting the error code 5Ab on my Maytag
You inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
To turn the Sabbath Mode on/off on your range simply press and hold the "Clock" button for 5 seconds. These instructions are on page 15 of your owner's manual.
If you have questions, please post back and let me know. I hope this helps you.
Posted on Nov 01, 2009
Testimonial: "Thank you sooooo much. Instead of paying a service call, we spent all of about 5 seconds and IT WORKS! We don't have a manuel so thanks very much."
blueextc3221
  • 15935 Answers
SOURCE: what is F1 on my maytag range model mer5570acw I
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
$%^Y
Posted on Oct 01, 2010
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
Oven: false lock error
Check your thermal regulator located on the back, it is most likel a 2 screw part replacement. Thats What it was on ours, very quick and easy fix.
Jan 14, 2018 | Maytag PER5710 Performa Electric Kitchen...
My top oven on the maytag "gemini" doesn't work! it is a gas oven.
1) Confirm if its just the bake or both bake and broil that doesn't work. 2) If its just the bake you will most likely need to replace the bake ignitor. 3) If its both you need to test for voltage output from the electronic control to the ignitors.
Jan 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag oven top heating element won't come on unless on broil
You are probably going to find the lower heating element has failed. Your symptoms describe that failure exactly.
Reply back if you want instruction as to how to repair.
Feb 15, 2009 | Whirlpool RBS275PD Electric Single Oven
Amana Range, Electric wont bake or broil
the fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Mar 23, 2008 | Kitchen Ranges
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Maytag PER5710 Performa Electric Kitchen Range Logo
75 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
