Question about GE Refrigerators
Hi i have a GE frigerator model number pds22mcrbbb bottom freezer. the temp for the freezer and frig do not stay lit after setting them. after setting the temps they do not go off when you depress the door closure button. they only stay lit for about 10 minutes when you set them and then never come back on... cdm
  • 2 more comments
  • charlesdmark Feb 06, 2010
    still not sure that will let me know if the mother board is no good... the temp displays for freezer and frig go out after 10 minutes...In order to see them again you have to press each one.... i have another ge frig to compare it to.. cdm
    have ge pds22mcrbbb refirgerator. after setting the temps for the frig and freezer they go blank after 10 minutes....
    have ge pds22mcrbbb refirgerator. after setting the temps for the frig and freezer they go blank after 10 minutes.... also when they are on for 10 minutes the will not go off when you push the door button. i have a another frig like it to compare it to.. cdm thanks
    thanks... figured that... read some other issues on-line close to my problem....and they talked about the motherboard... thanks again cdm
  • 1,543 Answers
This is actually a problem with your motherboard, located behind the refrigerator. (look for a rectangular cover, held on by usually 3 screws)
Replace the motherboard as soon as possible, or you will very soon see cooling performance issues.
Posted on Feb 06, 2010
  • Carl Schulzetenberg
    Carl Schulzetenberg Feb 17, 2010
    No, you won't have a good spare, you will have a working refrig and an old bad board. I have run in to this exact situation several times.
  • GE Master
  • 8,220 Answers
After you set the temps the ice box will display the current temps inside both compartments. I am including my personal copy of the tech's repair manual and in it you will be able to do some checks and understand better how the controls work. Using the diagnostics tests in this manual should give you an idea of how to solve this problem. Anyone can say ok run out and buy a new control and when the problem still persists and you find out it is a cheapazs thermistor then that is aggravating. I have the exact repair manual for your ice box sir right HERE
  • 1 more comment
  • Dan Webster
    Dan Webster Feb 06, 2010
    Go on and replace the mutha board. At least you will have a good spare.
  • Dan Webster
    Dan Webster Feb 20, 2010
    Let us know.
  • Dan Webster
    Dan Webster Feb 24, 2010
    I wonder was the motherboard replaced and the result?
My GE Profile side by side fridge freeze the food in the bottom draw. I have set the temp to 43F but keep the fridge at 34 or colder. It frooze the water lines and tank in the fridge several times. What am...
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
May 27, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
The temperature is set correctly but the top portion of the refrig does not stay cold (and goes up to 60 degrees) while the freezer gets too cold (and goes to -11). We cleaned the vent on the motor and...
Sounds like the ductwork inside the fridge that connects to the freezer is either partially blocked with ice or the damper flap is stuck in that duct.Please let me know if this helps, a good defrost should cure it if it is
Jan 19, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Refrigertor setting out
hi there,
your problem can only be fixed by a professional, please call your local repairman to fix this.
May 11, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Bulbs burning and causing frig to get hot.
I need the model number you may have a short and lights are reaming on while door is closed. This sounds like a recall or fire hazard Unplug let the area cool remove the bulbs or risk property damage until confirmed what model you have Sea Breeze
Dec 13, 2009 | GE Refrigerators
Refrigerator is freezing
if you turn up the temp in freezer and down on frig side and frig still freeze's than more than likly you have a bad frigerator thermastate.
Nov 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Ge profile fridge will not cool
i would check to make sure you can hear the fan in the freezer you may need to hold in the door switch
Oct 08, 2009 | Refrigerators
Frigerator will not cool , freezer operates, coils cleaned, fan operating
On line diagram of frig and concluded that it was the upper fan (motor) in the freezer. Air was not being transferred to the bottom portion of the frig.
Sep 05, 2009 | Kenmore Refrigerators
Not maintaining set temps but holds steady at 31 and 61
Could you double check your model number the number above your post is nothing like the refrigerator2.gif you are describing, Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 10, 2009 | GE PDS22LBN Bottom Freezer French Door...
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
