Question about Reiker Room Conditioner Ceiling Fan with Heater RRC12001
Light flashes, clicking noise, fan does not turn
When we go to turn it on, the light flashes and the unit makes a constant clicking noise. Also, the fan blades do not turn. If we let it stay in this condition for abuot 15 minutes, it eventually starts to work. What is the problem?
    Problem Solver:
  • 10 Answers
It sounds like the motor has a weak start winding or if the unit has a start capasitor it is bad
Posted on Feb 06, 2010
Hunter fan Model 20722 lights flash several times when turned on?
Not the capacitor. If this fan has a remote make sure it's set for incandescent bulb & not CFL bulb. Should be where you install the battery. Also, make sure you're using the correct wattage as it might have a limiter in the fan.
Dec 05, 2015 | Hunter Dryers
Constant flashing red light near on/off switch
i think it is the power supply board problem
Nov 05, 2013 | Televison & Video
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
SPEEDLITE 580EX TTL Flash: flash is making a constant beating/clicking noise ...
Loosen the two small screws under the flash on the swivel head. Turn flash on. You may need to twist the head just slightly. Flash bulb moves back and forth in the swivel head when zooming. If you dropped the flash, this may have jarred it from the track. I had the same problem with mine, and the above solution fixed it. Zoom works again and no clicking noise. Let me know.
May 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
No light and some fan noise
Take the top off and verify that all of the fans are on, there are 2 behind the power supply and one behind the engine. If the unit lights up when the top is off, then the wires above the dual fan assy may be putting pressure on the fan frame while the top is on causing one to rub or not turn at all. If this is the case, unplug the power and try to route the cables thru the notch in the top of the fan assy a little better. If any fan isn't working, the unit will not light. This could be due to a main board problem or a bad fan itself. If the colorwheel is stuck, the unit will light and then shut off. Also, depending on the age of the projector, if there isn't a green wire going from the front of the main board to the bottom of the power supply ballast, the power supply will need to be replaced or upgraded by a technician.
May 03, 2010 | InFocus LP70+ Multimedia Projector
BenQ DX 650 Won't power up making clicking noise
Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
Mar 10, 2017 | BenQ DX 650 Multimedia Projector
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Reiker Room Conditioner Ceiling Fan with Heater RRC12001 Logo
334 people viewed this question
Top Reiker Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Reiker Heating and Cooling Expert? Answer questions, earn points and help others
