Question about Amana Washing Machines
OUT OF BALANCE ON SPIN CYCLE. model LWA50AW - Amana Washing Machines
  • 129 Answers
Does the unit leak water or make a noise while spinning ? Its may be the triple seal bearing kit in the inner tub going out .With the model and serial numbers the warranty can be checked to see if the parts are under warranty.If the seal kit is going bad it takes about 3 or 4 hours to replace , some times it will damage the transmission as well. The unit has 9 springs under the tub to help keep it balanced . by removing the front panel you can run the washer to better see the problem.
Posted on Feb 06, 2010
  • ARNETTSREPAI Feb 06, 2010
    The inner tub may have come apart take the top off the agitator remove the bolt take the agitator out and check the bolts holding the inner tub in place.
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
Spin cycle loud vibration problems on spin cycle
What is the complete model number of your unit?
Dec 04, 2012 | Washing Machines
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Is off balance during the spin cycle mor often
I have a 10yr old Maytag Atlantis model MAV7258AWW. Here is how I solved my balance problem. It appeared that I had two problems. One was that it would not spin fast, the second was that it would spin off balance. To get the washer to spin fast like it should I had to open the lid then close it, re-engaging the spin cycle. I opened the top and watched the motor engage in the spin cycle. with the top open, I would open and close the lid activating the lid switch. Each time I closed the lid I noticed that the motor would move a little bit more on its glides to tighten the belt. Sort of like a automatic adjuster. The motor is designed to pivot one way for the agitator the other way for spin. If the motor does not pivot correctly, the belt will not tighten and will slip. I removed the front panel, cleaned and lubed the pivot area. Now the motor glides on the pivots like it should. I ran the spin cycle and the motor slid all the way to one side like it should, the belt tightens and the spin cycle spins. Now that the spin cycle works, quess what?? The balance problem is fixed as well. It appears that the reason that the tub was going off balance was because the belt was slipping not spinning the tub at maxium speed as designed causing the off balance problem. The tub was not spinning fast enough causing the off balance problem. I have ran several loades in the washer and not a problem. I did replace the snubber, it was worn out but it still spun off balance. I hope this helps to all who have a balance problem.
Mar 02, 2010 | Washing Machines
Noise in the spin mode on a Amana LWA50AW top load washer
Based on your description, it sounds as if your outer spin bearing is faulty. See link below for an illustration of the bearing. Special tools are required to replace this item.
Illustration provided by; www.repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-ALW480DA-%3d%3di549695&PartID=549695
Aug 07, 2009 | Amana ALW480DA Top Load Washer
Will not spin or agitate
Get the model number. It may have an off balance switch that is stuck. Try moving agitator like its off balance and then turn on.
May 18, 2009 | Washing Machines
Amana washer LWA50AW
I had the same issue last year on y lwa50aw. It is the timer. Get the speedqueen version it is about $50 -$80 and aboyt 15 minutes to replace.
Apr 19, 2009 | Amana LWA40A
Amana Washer LWA50AW doesn't spin
Ifi t does not spin it may be the timer. Try it in the delicate cycle to see what happens. Actually try all teh cycles to see if it spins in one of them. IF so it most likely is the time and is a 15minute job to replace.
Feb 26, 2009 | Amana ALW480DA Top Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
136 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
