Question about Car Audio & Video
I need a wirng diagram for a viper 5301 remote starter
    Sergeant:
  • 306 Answers
Vehicle will respond but not lock/unlock
reprogram the remotes by following the vehicles owner Manuel
if you can't get them reprogrammed then its dealer time.
Mar 11, 2014 | 5301 LE 2 Way Car Remote Starter System
Horn does not sound when locked by viper 5301
??? Have u tryed a new battary. ???? is there a way to re program it ck online or call the DLR..
Feb 05, 2012 | 5101 LE 1 Way Car Remote Starter System
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
I have a Viper 5301 LE 2 way remote starter system installed in a manual transmission. When I set my starter everything seems to be functioning normally. Once I get out of the car and hit the lock button...
It sounds like the turbo timer mode is active. In this procedure, the MTS remote starter is active, it's just that once set (after locking the vehicle) the vehicle will run the preset time(1,3,5 or 10 minutes) before shutting down. The MTS remote starter feature should still operate with the turbo timer mode.
Feb 08, 2011 | 5301 LE 2 Way Car Remote Starter System
Hooked up a Viper 5301 in a 2004 Nissan Murano. The problem I'm facing is that the unit is only programming when the vehicle is started and running, instead of programming after turning the ignition on...
It sounds like you have your ignition and starter wires reversed. The remote start programs when the ignition wire sees 12 volts and then loses the 12 volts. If you have the remote starts igniton wire on the trucks starter wire then that is why you can prgram it when you start it only... cause you get 12 volt only when the truck cranks and then loses the 12 volts once it is runnng. You may have the right colors from the remote starter correct but check to see if maybe from DEI they have the wires in the wrong positions.
Jan 20, 2011 | 5301 Responder LE 2Way Remote Start and...
Getting Viper 5301 to turn on heat fans in 2005 Mruano
Most likely only one of the cars 2 accessory circuits was powered up by the remote start. There definitely are 2 (red and white/blue). Please double check with multi-meter before just hooking up. But that should solve the no fan upon remote start.
Jan 29, 2010 | Remote Start System
Viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Jan 15, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
