Question about Life Fitness 9100 Next Generation Remanufactured Treadmill
Treadmill says "workout paused" about every 10 sec. when in use. How do I fix it?
  • 79 Answers
You must first check if the system is working wax, second this warming probably DECK. in this case you should replace it. You should also know if you have the connection with a dedicated electric circuit 20Amp and finally the last thing you should check is the "Emerson Controller"
Posted on Feb 06, 2010
I have a life fitness 9500hr treadmill. I cannot get any movement from the belt at all. I type in all the workout details and it says 'enjoy your workout', only the workout does come. There is a long pause...
More than likely, you will need to replace either your console or motor control board. They only way to tell is to test to the voltage and determine if there is a disconnect between one or the other. If you are in the united states, it is best to call a fitness equipment repair company. If you are in Georgia, visit www.AtlantaFitnessRepair.com
Dec 12, 2017 | Exercise & Fitness
What are some of the benefits of elliptical machines over treadmills?
Whereasa treadmill provides an "impact" workout, elliptical machines provide a "no-impact" workout. This makes workouts on the elliptical trainerhave much less stress on the knees, hips, and joints.
Aug 05, 2012 | Exercise & Fitness
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    I bought a Reebok V8.90 with iFit cards. My problem is that the workout will stop multiple times during the workout. Then I have to start over. It seems that each time I start over I can get a little...
    Dear Sir:
    I hope your are very well in union with your family.
    I will help you inmediatel.
    Please do the following:
    If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
    Here are the most common symptoms and solutions:
    1)
    Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill trips causing you to have to reset the breaker, or let it cool off then reset the breaker.
    The amount of time required to shut down will progressively get shorter.
    Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
    DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
    shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
    go for a cheap fix try lubricating the walking belt. The best fix is to replace the
    walking belt and then regularly maintain it and keep the treadmill clean.
    2)
    Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
    down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
    before it shuts down gets progressively shorter.
    Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
    electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
    the deck for wear too. If you want to go for a cheap fix try lubricating the walking
    belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
    3)
    Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
    shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
    reset it to restart the treadmill.
    Solution: If you get an error code, contact us with the code and make and model and we will try to help
    you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
    board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all
    your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
    case corrosion is causing.
    Thank you in advance, sincerely. God bless you.
    If you need further assistance,please contact us.
    E.CUADRA
    MANAGUA, NICARAGUA. C.A.
    Sep 27, 2011 | Exercise & Fitness
    Just purchased a new Nordic Track T7.3 treadmill. Set it up and completed one perfomance workout plus 3/4 of a weight loss workout when disaster struck. The mill was placed on pause and when the start...
    Just had mine delivered on February 11th. Ran on it once and the screen went to complete contrast darkness. You could still see the display but you could see it better at an angle than you could looking right at it.
    Got on it today and the screen was completely blank just like you (after 6 uses). Sears came and the guy said the screens on these treadmills were junk.
    Apparently Sears will be replacing our treadmill at some point!
    Mike
    Jan 10, 2011 | Nordic Track NordicTrack T7 si Treadmill
    Life fitness treadmill display: transistor error-won't run
    This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
    Solution
    Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
    Feb 28, 2009 | Life Fitness Remanufactured Next...
    Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
    149 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Glenn Mayer
    Glenn Mayer
    Craig Butler
    Craig Butler
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
