Question about Dell Latitude C610 Notebook
I have 2 memory modules to increase my memory. How do I access the memory ports to insert/change them?
  • 37 Answers
Normally ther is 2 panels on the bottom of the laptop both can be removed by unscrewing them. one will give you access to the hard drive and wireless card , the other to cpu and memory slots
Posted on Feb 05, 2010
ASUS MINI LAPTOP RAM CHANGING METHOD
Basically one removes the underside cover to access the memory modules. Then remove the modules by releasing/uncliping them at each side.
They will pop right out. Now align the cutouts and insert the modules pushing them downwards into position.
Take care!
damnor01
Sep 11, 2012 | Acer Aspire Computers & Internet
How to install memory to my Acer Aspire 570 G Notebook PC
Most laptops have a panel on the bottom of the laptop that provides access to the RAM memory slot/s. Remove this panel to reveal the RAM slot, Insert a RAM module that is the same make and model as the original one.
If your laptop has a single 512Mb RAM module then add another 512Mb of RAM to increase the total RAM to 1Gb.
Feb 24, 2012 | Acer Aspire Notebook PC
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
I tried to change the ram on my asus laptop and turned it on and screen does not show anything but laptop turns on but black screen help me?
Good day.
Memory modules are sensitive. You must take a lot of care when handling memory modules.
The first question is why did you change the ram? Nevertheless, if the one you replace is certified in good condition, then the problem lies in the insertion of the new ram. First to note is the use of correct memory module type and speed. Use of incorrect type/speed may result to errors. Secondly,clean the module's contact points using an eraser. See to it that you align the module's cut (located in the contact point) to the proper slot in the memory module's slot. Do not force to insert the memory module if it is not in the proper slot, it will break the board and/or the memory module. You can hear a slight click sound or a firm position signifying you have correctly inserted the memory module. Power on test your laptop. If you have more than one modules, you may try one another to isolate defective one.
Feel free to post your problems here at Fixya.
Good luck.
Tedmac
Oct 08, 2010 | Computers & Internet
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
I added more memory to my vista
Has the BIOS detected the additional memory or it has stayed the same?
Is the new RAM the same make as the other RAM module and speed?
To determine if the new RAM is OK, remove both RAM modules and insert only the new RAM module and see if the laptop boots up.
If it doesn't boot up then the RAM module is either faulty or incompatible with your laptop.
If it boots up then insert the other RAM module in the second memory slot. Check the BIOS to see if the RAM has increased. If not then the RAM modules are incompatible with each other. I suggest you look at the make of the original RAM module and purchase the second one from the same manufacturer.
Aug 26, 2009 | Dell Computers & Internet
How much the memory on compaq v3000z can be increased and what type ddr, ddr2 or ddr3? currently it has 256.
Compaq Presario V V3000 Specification Memory Type: DDR2 SODIMM 200pin DDR SODIMM:
DDR, double data rate is a type of SDRAM in which data is sent on both the rising and falling edges of clock cycles in a data burst. It is usually referred to as DDR as opposed to DDR SDRAM.
SODIMM, small outline dual inline memory module. Smaller and thinner than standard DIMMs, SODIMMs are typically used in laptop computers.
Memory Speed: PC2-4200, PC2-5300 Chipset: Intel 945GM Chipset :
A group of chips that together make up a complete computer processing unit, usually on one circuit board (the motherboard). It may include the main central processor, graphics processors, secondary cache memory, and input-output controllers. Memory is one component controlled by the chipset. Standard Memory: 512MB Removable Memory Slot(s): 2 Max. Memory Per System: 2048MB (2GB) Max. Memory Per Slot: 2048MB (2GB) Dual Channel Memory Support: Supported Dual Channel :
A development in motherboard and chipset design that allows for increased bandwidth transfer when using two or more memory modules in separate transfer channels. These separate channels allow each module access to the memory controller, increasing throughput bandwidth. It is a good idea to use matched pairs of modules to ensure the best compatibility for dual channel operation. Tri-Channel Memory Support: Not Support Tri-Channel :
A development in motherboard and chipset design that allows for increased bandwidth transfer when using three or more memory modules in separate transfer channels. These separate channels allow each module access to the memory controller, increasing throughput bandwidth. It is a good idea to use matched three modules to ensure the best compatibility for tri-channel operation. Install Memory in Pairs: Not Required Install in Pairs :
Memory modules must be installed in pairs of matched memory size. This means that if you purchased your computer with 128 MB of memory installed and you want to add another 512 MB of memory, you must remove the two continuity modules and replace them with two 256-MB memory modules.
Aug 19, 2009 | HP Compaq Presario v3000z Notebook
Speed of print
A printer is designed to print at a certain ppm (page per minute), so really there is only one way to speed it up. When you select the print option from the File menu, you can select properties and see if you can change the dpi (dots per inch) of the document. Your document will print faster but you will lose quality.
Nov 27, 2008 | Epson LQ-2180 Dot Matrix Printer
Help!
  • CPU: Intel CeleronD 2.66GHz CPU
  • Motherboard: ECS 661FX-M
  • Chipset: SiS 661FX
  • Devices
    • 40 GB HDD
    • Combo DVD-ROM/CDRW Drive
    • Floppy drive
  • Memory: 128MB DDR333
  • Operation System: Windows XP Home Edition SP2
  • Accessories Box
    • Keyboard
    • Mouse w/scroll wheel
    • Stereo Speakers
  • Features
    • Integrated SiS Real256E Graphics. SMA up to 64M.
    • Open AGP 8x slot, 3 x PCI slots (1 used)
    • 6 x USB ports (4 back, 2 front)
    • Build in AC97 audio codec.
    • 10/100 build in onboard LAN port and 56K Modem
  • Dec 07, 2007 | EliteGroup ECS u-Buddie UB-Em22+ PC...
    Compaq armada e500 memory
    memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
    Nov 13, 2007 | Compaq Armada E500 Notebook
    Dell Latitude C610 Notebook Logo
    Alun Cox
