Question about Microwave Ovens
Panasonic microwae h964bf comes on for 3to 4 secs shuts down and you can smell electrical
  • 72 Answers
Your magnetron is bad and it burned the diodes on the inverter board. not worth repairing it
Posted on Feb 06, 2010
Panasonic nnt553 top got hot smelt like bakelite burning then stopped working.
probably ur stirrer motor burn or temperature cut off tripping due to hi temp of ur cavity casuse by defective coling fan
Feb 21, 2015 | Panasonic Microwave Ovens
How do I replace the light in my Panasonic nn797s?
Remove the case and replace the lamp located between the magnetron tube and the control panel. If I remember correctly there is one phillip screw holding the base to the oven.
Oct 12, 2014 | Panasonic Luxury Full-Size 2.2 Cu. Ft....
Panasonic NN-A755
It does sound like the magnetron is failing, when it shuts down it is because the thermal fuse is detecting to much heat from the magnetron and shutting it down, I might add this part is the heart of the system, rough cost would be in the area of $100.00 maybe cheaper. Intallation of this part is very tricky and there is the danger of high voltage, I recommend a pro for safety and correct installation.
Apr 12, 2012 | Panasonic Microwave Ovens
Hello i do not have the instruction for my bread maker. where can i get another copy. thanks
/turn it on 4-5 sec it shuts down display still lites unpluged for a min. tryed again same thing
Dec 07, 2010 | Panasonic NN-T993SF Microwave Oven
My panasonic microwae stops after 28sec and would'nt work
Is it maybe 22 seconds?
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Sep 21, 2008 | Panasonic Microwave Ovens
Runs for 3 seconds
check inverter transter or Magnetron short to be repalce
G.K.MAHENDRAN.
Date: 09.05.2008
May 07, 2008 | Panasonic NN-S540 Microwave Oven
Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 20, 2007 | Panasonic NN-T694SF Microwave Oven
Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Nov 17, 2006 | KitchenAid KCMS145J Microwave Oven
Microwave Problems
Thats exactly why so so many repair shops have closed their doors mOH NO not because of you!!!lol its because of items are made to last a year or so and they are so inexpernsive theythrow them away and simply buys a new one cause for 100 bucks who can blame ya. your problem should be looked at by a pro unless you know how to deal with electricity and charged capacitors. it will run between 15 to 45 to check out the unit and probably cost about 50 to 100 bucks if not more to fix see my point? Buy A new one. Good Luck .
May 30, 2006 | Panasonic NN-S541 Microwave Oven
Microwave Ovens Logo
85 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
