Question about Denon AVR-1705 Receiver
Denon A 1705 will not produce anything on the output from several of its audio inputs
  • Mik2345x Feb 08, 2010
    I am sorry, i did not give you enough info:
    Some of the audio inputs work all right, some not at all.
  • 5,807 Answers
Servicing the unit requires a service manual like the one here @
http://www.s100-manuals.com/search.asp?q=denon%20avr%2017
a ) You need to open the unit and check for regulators, protection
circuits, preamplifier circuits and the main amp circuits.
b ) These trouble can be attributed to loose of audio
signal being sent to each main amp of the unit.
c) These can also possibly be from the protection circuits or
to the microprocessor .
d ) To start diagnosing the unit measure offset voltages on each
main amp output stage particularly on the center of the twin resistor
or to the test point indicated on the board.
e ) Having an over of 0.7V will activate the protection circuits thus
having no output on the speakers and sometimes will show
Protect indicator on the panel.
f ) Although at times , one way to tackle circuits like these is to
have a signal tracer.
here is a tip just in case you need to have an overview how to
troubleshoot the missing audio, these one is more basic than yours
but the principle is the same.
http://www.fixya.com/support/r4008719-diagnose_not_having_audio_right_channel
g ) These are just for the process of eliminating the cause, till
we can prove something then that would be the area we will be
concentrating on.
Let me know if you need further assistance after probing around.
Thank you for choosing FixYa for assistance. I hope that my
information proves useful to you. If so, please take a moment
to provide me with a positive rating. I'd really appreciate it.
Regards,
palaboy
Posted on Feb 06, 2010
  • Rommel Cana
    Rommel Cana Feb 08, 2010
    a ) troubleshooting is the same on the non-working input
    b ) possibilities are
    1 ) just a loose cable connection
    2 ) settings on the audio
    c ) If you have a signal tracer , then it would be easier on your part.
    d ) Indicate what input doesn't work , will try to work these out
Audio very muffled.
Your Denon AVR output is being clipped severely because of improper Speaker impedance or wrong interconnection of inputs check that out why don't play the Tuner and notice
Jun 24, 2015 | Denon Avr-2308ci Home Theatre Receiver...
Denon DP300F no audio output to harman kardon 158 reciever
A turntable can NOT be connected direct via a tape input on any amp. Magnetic Cartridges require a special socket often called a "phono" input. If your receiver doesn't have a dedicated socket, by the sound of it doesn't, then you need to get a magnetic cartridge pre-amp. The turntable will plug into this and that will plug into the tape input on your receiver.
Jun 02, 2013 | Audio Players & Recorders
Fixing a Denon 1705. Rear Surrounds damaged by 2ohm speakers.
Chances are that you blew your output transistors with speaker impedance that low
Apr 16, 2017 | Denon Audio Players & Recorders
I have a Denon AVR 1705 and can get a tv picture and no sound or sound with no picture. Is there a setting or selection that I am missing to have both.
Sounds like the sound inputs have been reassigned to another input-
You'll ideally need the instructions to give a fuller idea of how you adjust these and all the options it gives you
Sep 03, 2010 | Denon AVR-1705 Receiver
Trip problem
If your receiver goes in to the protect mode or shuts off you have shorted output transistors
Apr 10, 2010 | Denon AVR-1705 Receiver
Video does not work All this while, I had never used the video components of my AVR 1705. Recently, i wanted to connect the component out of the cable set top box and dvd player to the avr and the output...
Hi
The settings on many DVD players and TVs may need to be set to indicate the type of input/output being used(RGB vs YUV/YPbPr, and if set wrong the image may not be properly displayed. Try Look for such settings in your TV and/or Amp!
Good luck
Bruce
Dec 07, 2009 | Denon AVR-1705 Receiver
Denon AVR-1705 Missing Video Functions?
What you need to do is connect all your devices to the Denon Using the best connections (Yellow Video=OK, S-Video=good, Component green-red-blue=better and HDMI=best. if you do not have a DVD that upconverts to 1080i or p when using HDMI, I would use component cables where available from your devices to the Denon other wise use the next best connection available and if connecting digital audio make a chart of all connection so you can setup everything when your ready for programming the Denon
Feb 11, 2009 | Denon AVR-1705 Receiver
No Video from Denon AVR-588
It cant up-convert component to hdmi. Input and output has to be the same. However, you wont lose anything cuz hdmi and component are comparable
Nov 24, 2008 | Denon Audio Players & Recorders
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
Denon AVR-1705 Receiver Logo
98 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
