Question about Brother HL 2140 Laser Printer
How do I remove pieces of paper stuck in the HL-2140 Laser Printer?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Turn printer off and unplug the printer from all cables (power, USB, etc). Try to hold it upside down and gently shake it so that if there is any paper inside it’s removed. If still it’s not resolved then clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 05, 2010
HL 2140. How do you remove jammed paper from inside printer
You can remove the jammed paper by removing the drum and toner inside the printer.
First Open the front cover, just pull down the cover right above the brother logo. You will see the handle for the drum and toner. Hold the handle and pull it towards you, just use a little force on it. Then remove the jammed paper inside. Just to be sure you can remove the toner from the drum by holding down the green tab on the side of the drum unit. then pull the toner out. Check if there's a small piece of paper inside the drum unit. Put the toner back to the drum make sure it clicks into place. Reinstall the drum and toner back to the printer. It should also click into place. Then close the cover.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother HL 2140 Laser Printer
How could i fix paper jam on Brother HL-2140 Laser Printer?
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Jan 12, 2011 | Brother HL 2140 Laser Printer
How to remove paper jam in brother hl-2140
Open the front door, remove the cartridge/drum...slowly slight the paper out. if it jams at the back ...do the same but rotate the fuser gear..if it jams on the tray not pull as it would cause the paper to break and sensors might get dmaged,
Sep 22, 2010 | Brother HL 2140 Laser Printer
Paper jam - where do I get instructions on how to fix?
To remove the paperjam in machine you need to:
Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well. Remove the paper tray there could be a piece of paper stuck there.
Wherever you find the Jam remove it slowly so it doesnt rip.
Jun 24, 2010 | Brother HL 2140 Laser Printer
Paper jam in brother laser printer Hl 2140 can help plse?
Here is the solution------
1. Open the Front cover of the printer. 2.Remove the cartridge and look inside the printer for jammed paper. 3.If any jammed paper found remove it. 4.Insert the cartridge again. 5.Closed the front cover.
It will help to solve your printer problem..
Jun 03, 2010 | Brother HL-2040 Laser Printer
Manual paper feed works but not automatic feed.
I've been told labels have to be manually fed on that printer.
Mar 30, 2010 | Brother HL 2140 Laser Printer
Error
Make sure there is not a piece of misfed paper in there. This happened to me and it took a while before I figured it out. Open the upper top and try to remove the toner. If it is stuck, more than likely there is a piece of paper stuck in there. Hope that helps.
Aug 16, 2008 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
