Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
How to make the kegerator colder - Danby DKC646BLS Full Size / Pony Beer Keg Cooler
  • corona4mcgar
    corona4mcgar Jul 14, 2012
    i cant lower my temperature on the blue led. every time i push the down arrow it switched from F to C, in stead of lowering the temp. but if i hit the up arrow the temp will rise. what's wrong with this thing?
  • Danby Master
  • 3,740 Answers
From the operators Manual page 14:
http://www.manualnguide.com/dl/20835/
Each depression of the up or down arrow will
increase or decrease the temperature
incrementally by 1º (F/C) until the desired setting
is reached. The temperature can be set between
36-46º F (2-8º C).
Danby Phone:
1-800-263-2629
*Note: the display will flash for 5 seconds from
the time the last button was activated before
resuming display of the internal temperature of
the cabinet.
Posted on Feb 05, 2010
  • Kelly
    Kelly Feb 06, 2010
    Not sure why the disatisfaction but the unit can only be adjusted from 36 - 46 F or (2 - 8 deg C). You can not change that. If there is something more you need or wanted just reply and we can assist you. Take care.
  • Kelly
    Kelly Feb 06, 2010
    Not sure if your asking how to modify the unit from other than the factory capable settings. The question was how to make it colder. "how to make the kegerator colder" Again thanks for using Fixya. If you need anything more we will be available here. Thanks.
My thermostat shows its on but i cant change the temp
Posted on Jun 24, 2010
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Beverage Air Kegerator Runs constantly gets too cold
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
Apr 29, 2013 | Beverage-Air Refrigerators
Replacing true kegerator parts
no use a Ranco p# A12-700 make sure the capillary is in the coilto sense the temp and set it to 1.5 on the knob. any colder and it could get too cold . you may be able to set it at 2 but be careful. it is a constant cut in at 37 degrees coil temp. the box temp will drop to usually to 28 or 29 at cut out.
Dec 31, 2012 | True Direct Draw Systems: Kegerator...
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
Nov 16, 2012 | True Direct Draw Systems: Kegerator TDD-2
Kegerator is pouring all foam
Try rinsing all that foam out, dry it out with hair dryer and begin again AFTER reading the WHOLE operators manual. No one ever reads the instructions. If all else fails you may have to exchange or replace the unit.
Sep 03, 2012 | Haier SS Half Kegerator
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Does anyone know anything about kegerators?
first send it to me with a full keg so i can check it out what make and model is it and how are you pressuring have you checked the pressure gauge to see what happens when you open the tap
Dec 31, 2007 | Summit Commercial 500SS Draft Beer...
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
2,002 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
