Question about Dell Dimension E510 PC Desktop
I just want to reset my pc to factory settings. when i boot up my computer i get a black screen with "press f2 for startup". Trying to play games on it is bad because the colors and graphics are all wrong, and they work just fine on a different computer. How can i reset my computer to factory, like new, just out of the box settings?
    Scholar:
  • 191 Answers
If your computer has a FACTORY RECOVERY partition then you can boot into that and restore your computer to like new state. WARNING YOU WILL LOSE ALL PERSONAL DATA. If it does not have a factory restore partition you must incert and boot from the factory image CD's you should have got these when your computer was brand new. You can order these CD's from the manufacture of your computer (for a price) if you do not have them. OR you could take your computer to a local computer shop and have them re-load it. cost varries from = $60 to $150 typically. I personally work for TechSupportPros of Spokane WA and would charge $60 for this service.
Posted on Feb 05, 2010
A mannuel for a sylvania netbook
  1. Turn on the Netbook Start up the Netbook as usual, but instead of watching it load, immediately press the F2 key until the Setup Utility screen appears.
  2. Disable the Boot Booster Use the arrows to select the Boot tab. Click the Boot Booster option, then press Enter to disable it. Move to the last tab, then select Exit and Save Changes.
  3. Restart the Netbook Restart the Netbook, and press and hold F9 as the computer restarts until you see the loading screen. Click the "?" key to confirm when a message appears asking if you want to perform the operation.
  4. Wait as the process completes Do nothing as the restore process starts and completes. No human interaction is needed to finish the process. The computer reboots on its own and makes new configurations. The computer then automatically restarts again. At this point, the computer is now fully restored to its factory settings.
Jul 28, 2016 | Sylvania Synet7wic-bk-z2 Netbook
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
How do i reset my dell latitude x12 to factory settings
Hi Steven,
Boot the computer and watch for the black boot up screen. It will only show for a few seconds but somewhere through the boot process, a line message in white text will say...either 'to enter the bios press F2' or, 'to enter Setup, press F2'.
The F buttons are on the top row of your keyboard.
So press F2 at the appropriate time and you will find yourself in the Setup area. The graphics will look cruder than usual - that is normal.
Your mouse won't work to allow you to move you around in there, so use the keyboard arrow keys to move the cursor and 'return' to open other options and follow the instructions to move left, right etc.
Look for a command 'Restore Factory Defaults and Exit?' toggle to it to highlight and Enter. Then enter a 'Y' for yes, Enter again and the PC should re-boot and be as good as it was on day one.
Cheers,
Tom
May 13, 2014 | Acer Aspire AM1640-U1401A Desktop PC
I want to resetmy asus eee pc to factory settings before selling it. i have tried the following: pressing the reset button with netbook totally turned off and disconnected; pressing the reset button with...
Open the display and click the "Shut down" tab in the lower-right corner of the desktop. Click "Yes" to confirm. Then power on your laptop, and press the "F9" key when the logo screen appears. A menu will display with a list of three options. Select the "Restore Factory Settings" option. Select "Yes" when prompted, then press the "Enter" key to reboot. Wait for the system to restart, then agree to the licensing agreement when prompted. Confirm your name, password and time and date when prompted. Then wait as your computer reconfigures. It should now have the original factory settings.
  • Jan 01, 2014 | Televison & Video
    How to set my acer laptop to factory settings
    Reinstall Windows is the only way to take it back to previous state.
    Feb 28, 2011 | Acer (ACERMOTHERBOARD)
    On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
    This indicates that your computer is configured to boot on the floppy drive.
    1. At the start of the computer Press F2
    2. Go to the Boot Device Configuration.
    3. Enable Hard Disk Boot Priority.
    4. Set the First Boot Priority to Hard Disk
    5. Save and Exit.
    Please let me know of the outcome. Thank you and regards.
    Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
    How do I reset bios on emachine d3415
    When you say reset...do you mean that you want to restore the bios back to their original factory settings?
    That can usually be done from the bios (reboot, press either F2 or F10...the screen that displays upon boot will let you know what to press) ...there should be an option to re-set the bios back to the factory settings.....
    But if that is not wat you are trying to do, let me know.
    May 08, 2009 | E-Machines eMachines Desktop PC
    HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
    Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
    Mar 06, 2009 | HP Compaq d530 SFF PC Desktop
    Edited boot config now computer beeps three times fans turn on high and screen stays black
    You can restore the "menu" of the "startup" to how it was before.
    The idea is to reset the CMOS/BIOS to the original factory settings.  There are 2 ways of doing this:
    1. Is to hit F2 again and look for Default Settings, click on that, save and exit; or
    2. (Preferably), open your PC and look for the reset jumper (3 terminal with 2 shorted via a jumper). This is normally located very near the backup Lithium battery. Temporarily, move the jumper to the opposite pair and replace back to original position after a couple of seconds.
    Hope this be of some help/idea. Post back how things turn up or should you need additional information..
    Good luck and kind regards.
    Nov 01, 2007 | E-Machines GM5260 (1009304) PC Desktop
    Startup problem
    This could be a corrupt bios or a low cmos battery, follow instructions. Take the right hand side panel off the pc. Look for a disc shaped 3V watch type battery and replace (Very cheap) Look on the motherboard and reset the bios at the 'JBAT1' terminal put jumper(little plastic cap) from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Restart pc and enter bios when prompted(or press F2 or DEL on startup) to set time and date, save settings and Exit bios. It should now boot ok.
    Jan 25, 2007 | Systemax AOL Optimized PC (100607) PC...
    Dell Dimension E510 PC Desktop Logo
    395 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
