Question about Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Water ace pump it will pump it out but it comes back in
  • 59 Answers
Do you mean it won't pump last inch of water or so? sump pumps are not designed to pump completely dry. vane pumps will pump dry. If you are pumping from one tank to another and after pumping is complete, and fluids transfer back, install a check valve on output hose to prevent back-siphoning , or don't submerge output hose on other tank. Hope this helps.
Posted on Feb 06, 2010
2003 honda shadow 750 ace water pump gasket leaking. Can I replace the gasket only?
There is a round o-ring that seals the water pump to the motor (oil seal). Then there is a shaped cover o-ring that seals anti-freeze into the pump. The cover o-ring is also replaceable. If your pump has coolant leaking it is probably coming from a small weep hole in the bottom of the pump. Check where the leak is carefully, my guess is that the water pump seal is bad and you actually need to replace the water pump assembly. To see a break down of the pump look here.
http://www.bikebandit.com/houseofmotorcycles/2002-honda-vt750cda-shadow-ace-deluxe-black/o/m2894#sch94027
Mar 17, 2011 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Rs3 will not come on. Does it have to be in water?
Hi, yes must only be used in water, also check the position of the float which activates the pump. Hope this helps
Jun 24, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I have a ace 1/3 hp sump pump it will not come on, what could be the problem
possibly the mechanical mechanisim that is attached to the water level indicator is not switching your pump on properly. could be broken internally or the linkage is set up wrong.
of course there may be other issues like the power source or the motor itself or the thing has siezed up.
Mar 01, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
1998 HONDA SHADOW 1100 ACE TOURER AS I WAS
you might want to have your water pump looked at.
Jan 20, 2010 | 1998 Honda VT 1100 C Shadow Spirit
1hp Water Ace dual jet water pump hums, doesn't pump
DOES YOUR NEW MOTOR HAVE A START CAPACITOR BUILT INSIDE OF IT TO HELP IT START. OR DOES IT REQUIRE A CAPCITOR START / RELAY BOX ABOVEGROUND. ALSO IF YOUR OLD MOTOR WAS 220V AND THE NEW ONE IS 115V YOU HAVE 2 HOT WIRES AND NO NEUTRAL. THE NEW MOTOR REQUIRES 1 HOT AND 1 NEUTRAL. HOPE THIS HELPS, JODY
Jul 18, 2009 | Plumbing
Replacing float switch on water ace r3s pump
I have been in this business for a ong time 34 years by the time ou take the pump apart and find the right peices it would be cheaper to buy a new pump, suggest zoeller submersable pump,,
Mar 17, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
New water ace sump pump will run but willnot shut off
The higher you pump the water, the stronger your pump needs to be, or the skinnier your hose needs to be. A lower discharge point and / or a smaller diameter hose might help immensely.
Mar 01, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Logo
198 people viewed this question
Top Water Electrical Supplies Experts
Lawrence Oravetz
Ottoniel
Are you a Water Electrical Supply Expert? Answer questions, earn points and help others
