Question about HP Photosmart C6180 All-In-One InkJet Printer
Replaced all ink cartridges on hp photosmart c5100 and now getting code oxc18a0201
I just replaced the cartriges in my photosmart C6180 after it was in storage for months. The error I get is 0xc18a0408 which is an ink system failure. How do I fix this so that I can print again?
hi
go to this link and read the informationed about ink cartridge . after a while the ink dries up and needs to be replaced, as well the printhead may need attention (possible replacement)
if you need (extra information) some part numbers to order , see inofrmation below .
C9087-60023 Service station assembly - For conditioning the ink cartridges when the carriage is in its home position
C9087-60008 Ink delivery system assembly - For the Photosmart C7100/C6280/C5100 All-in-One printer series
cartridges = http://h20141.www2.hp.com/Hpparts/Search_Results.aspx?mscssid=0938C619D0FD4908A7A1F4891CAB246F&SearchIn=Product
manual = http://h10032.www1.hp.com/ctg/Manual/c00753187.pdf
hope this helps -- if it does, would you please rate my service to you
Nov 14, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One err oxc18a0201
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
good luck
Aug 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart c5100 0xc18a0307
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jun 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
Oxc18a0201 ink system failure. Apparently failed due to using non HP ink. HP recomends buying a refurbished replacement. The printer is HP photosmart C5180
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
May 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have lost my ink level viewer. Hp Photosmart c5100 series. It used to show everytime I printed but now it is not there and I can't seem to recall it.
Did you install non-authentic HP cartridges? It doesn't like that and witholds information as punishment.
Try putting the following address into your web browser:
http://192.168.1.6/
this brings up my ink levels. However, I don't understand these things and you may need your own individual printer specific code.
May 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7280 Ink System Failure
Contact HP for Care at 1-800-585-2494 Toll Free
Oct 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
Sep 14, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
529 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
