Question about Amana AER5715QAS Electric Kitchen Range
The oven will not operate at all.
While warming up my oven, I heard a loud sizzle and pop. Now the oven will not broil/bake. But the light still works and the cook top works as well.
  • 254 Answers
Check your broil and bake elements for any breaks in the coils.....u can turn off power to unit and remove the 2 srews usually on bake wall that hold element in place and pull out a lil bit and undo connections attached to each side, make sure they dont fall back behind cavity.....or u can pull unit out and remove back panel and check the elements for continuity with a meter.. it osunds like one of the elements burnt out , hope this helps
Posted on Feb 06, 2010
Was cooking I'n oven. Heard a big pop sound and saw lghtning I'n tne oven. Now oven will heat a little but won't cook or broil ?
That sounds like the heating element went out when it first goes it could look like a lightning strike. Replacing the bake or broil element ,depending which one was on at the time will fix your oven. If you were baking replace bake element if ya werebroiling replace that one.
Reply with EXACT model number and i'll give ya the part number
GENE
Aug 27, 2011 | Frigidaire Kitchen Ranges
The oven and broiler will not work. I replaced the oven heating element to no avail. I did here a pop before and it tripped the breaker. What could it be?
send the model number and brand name,you should check the parts with a meter so you don't go out and start buying parts and changing them when they are still good.if you heard a pop most of the time either the bake or broil element did break,when you are baking the broil element doe heat up,did you check the broil element?if not unplug the stove,pull out the broil element and with a meter check for continuity,if both elements are good the clock could be bad or a wire shorted but the only way to tell is by getting in there with a meter and start checking parts and wires,if you heard a pop something did either short out or a part is cooked,also check where the cord connects to the machine
Feb 11, 2011 | Kitchen Ranges
Oven will not heat
Since bake and broil use different elements, and it is unlikely both went out at once, and then I would suspect the switch instead of the elements.
May 09, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
While oven was on, heard loud pop. oven no longer
Sounds like your element wire shorted out on back of unit.Try removing back panel and cheak wire on bake element .MAKE SURE YOU UNPLUG OR TURN OFF BREAKER.Hope this helped you out:)
Mar 11, 2010 | Kenmore Kitchen Ranges
Burners Work, but Oven Won't - Display Dead
The oven elements may be burned out or the switch. Usually if you have an electrical outlet, it gets power from the oven circuit. See if the outlets are working, replace the fuse (sometimes you can't tell it is burned out. Depending on age, you may have to replace elements. Not likely both are gone. does it work on Broil or Bake? You could also, unplug the stove and carefully remove the back cover and look for wires that are dicoloured...or burned.
Mar 02, 2010 | Frigidaire FEF336BC Electric Kitchen Range
My wife heard a loud pop while baking, the oven will no longer bake, the stove top still works so does the clock ect. Elements are fine just don't warm up. I have a kenmore 790, is there a internal fuse...
Check the baking element, sometimes these will make a popping sound if they burn into. Also a lot of your components are behind the knob/clock area.
Feb 25, 2010 | Ovens
Oven not working
It sounds like the element/s have blown, especially if the fan is still working o/k.
You cannot always tell by looking at them if they are faulty or not.
Only way to be sure is to test them with a meter.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Frigidaire Ovens
Kenmore electric oven 790.9912 does not bake or broil. Stove top works. Heard loud clunk before oven stopped working.
SOUNDS LIKE THE THE HEATING ELEMENT BURNT OUT AND ALSO THE TERMOSTATS HAVE BLOWN, I WOULD SUGGEST YOU REPLACE ALL AND YOUR OVEN WILL WORK GREAT AGAIN.
Nov 05, 2009 | Kitchen Ranges
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Amana AER5715QAS Electric Kitchen Range Logo
245 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
