Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
RONNING MOTOR CC 5440M12 , I NEED THIS FOR COMPRESSOR
Why does my new motor trend power house jump starter with air compressor not take a charge from the a.c. or d.c. charger?
Contact manufacturer. If still under warranty they should replace. Sounds like the internal battery is dead...there has to be a little "juice" left in the battery for the charger to have a complete circuit to charge...some of these units take 24 or more hours on an initial charge.
Hope this helps,Ron
Nov 30, 2014 | Power Center Jumpstart 11-411
I have a Black Cat portable air compressor model BC2502. It doesn't build air just runs
Ron:
You have an air leak somewhere. I use a pump-spray bottle with a soap and water solution while the compressor is running. Spray the soap solution on each end of the copper tube leading from the compressor motor to the air tank and look for bubbles. Correct any bad connections (tighten and/or replace any packings) Spray each hose coupler with the solution and look for bubbles. If there are no leaks, you may have to remove the cylinder head and check the valves in the valve body between the cylinder head and the cylinder. You will need to buy replacement gaskets if you remove the head from the cylinder.
May 23, 2014 | Air Tools & Compressors
I have a 66 conversion Eagle Bus. Went to leave to go on vavca this am and low and behold, no a/c in fron rooftop unit. It is a duo therm , I was just using the bus yesterday and it was fine. I can hear...
Hi Ron,
This is a common problem... the motor that runs the fans... condenser and indoor blower, has gone bad...check the motor capacitor first, it may be the problem, bit often the motor goes completely...
Take the top off of your A/c and the motor will be right under the metal piece in the center...
heatman101
Sep 04, 2011 | Dometic Rooftop RV Air Conditioner
I have a Hitachi compressor EC12. Sometimes when
you may have some water build up pull the cover apart look at yor pistons for build up
Jan 07, 2010 | Hitachi EC12 Portable Electric 2hp Air...
1997 Yamaha Virago 1100 cc
RON YOU HAVE A BAD TCI OPEN AND INSPECT YOU WILL HAVE TONES OF GLE STUFF IN THEIER BUT GET IT OUT THEN CHECK TO FIND THE DAMAGE EITHER WAY LET ME NO I JUST WENT THROUGH THIS VERY EXPINSIVE NEW SO CHAT BEFORE YOU BUY IT WILL BE WORTH IT IF NOT REPAIRABLE CUTTER
Jul 11, 2009 | 1999 Yamaha V Star 1100 Custom
Correct rotation of copressor
Checked all the IR compressors in stock and all turn counter-clockwise facing pulley, however you could check the pump for fan angle on pulley. The fan on the compressor pulley blows air towards the pump. Generally, pumps turn CC because that would allow for the use of gasoline engines which all turn CC. Please email you questions, and Good Luck.
Jan 27, 2009 | Ingersoll Rand 2340/2475 Electric Air...
(I need a new electric motor for my air compressor. Where do I find one?
I think I can help you guys needing a replacement CC-5440M12 120V/60Hz Ronning Motor. I have been cleaning out my shop and I have four (4) of these used electric motors. All work fine. They still have the plastic fan blade on one end and the metal gear on the other. I actually have electric cords wired up on each of them that I used to make sure they worked.
Thought I would pass this information on to you. Thanks and have a great day.
Oct 07, 2008 | Dewalt 2 Hp 4 GAL Air Compressor
Ac compressor oil
First off is your compressor pre-lubed? to find out, remove shipping caps from ports and tip to side and see if any oil comes out. As a rule of thumb, The oil is sold in a small bottle pre measured for the entire system. 1/4 bottle per item (compressor, evaporator,condenser, and filter/dryer) The label showing cc's will do fine for your oil needs as the system will find its own level once activated. Oil continuously flows througout system. Need I remind you that when replacing compressor you should also replace filter/dryer so you do not repeat this job in two months.
Aug 03, 2008 | 1997 Dodge Ram 1500 Club Cab
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
232 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
