Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Wires behind the panel are unpluged
I need a wiring diagram to show me how to hook up the wires behind the controle panel
    Problem Solver:
  • 19 Answers
Go to www.desatech.com in the customer care center you will find a link to get owners manual. If they don't have the right owners manual look in the tech tips they have the diagrams in there also.
Posted on Feb 23, 2008
I have a kenmore model 790.46893900 glass cooktop 0ven and i need to no where each of the 6 wires hook up exactly? they are the wires in clock and control digital display.
There is an old saying amongst Technicians. If you don't have a wiring diagram, mark every wire where it goes before you unplug them. The oven should have a wiring diagram somewhere behind one of the covers. If it doesn't, you may need to contact Kenmore or one of their Agents to see if they have a service manual detailing the wiring connections. Sorry , but I don't have any info on Kenmores. I don't think they are sold in Australia.
Sep 15, 2015 | Kenmore Kitchen Ranges
Gh6177xps
Your full model number would be either GH6177XPS1, GH6177XPS2, GH6177XPS3, or GH6177XPS4 as found on the model tag. I mention that only if you need to order parts.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
On the tech sheet for our model, trouble code F7 is discussed:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See "Checking Inverters."
9. Check operation of all interlock switches.
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Sep 07, 2012 | Whirlpool Microwave Ovens
Need wiring diagram for dash lights
all the plugs should only go to one place you shouldnt be able to hook anything up in wrong place stretch harness out across where it goes start at the end and go from there u can do it
Sep 06, 2012 | 1991 Nissan Pathfinder
Need a wiring diagram for Whirlpool Velos Microwave (Model # GH7208XRS1).
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Let me know if I can help further.
May 24, 2011 | Microwave Ovens
Whirlpool cabrio wtw6700tu manual
I'm not sure what you're looking for in the manual, but exploded views can be found at www.appliancepartspros.com and if you need a wiring diagram or diagnostic test information, look for the diagram that manufacturers place inside the machines for repair people. It is usually located behind the control panel. Unplug it and take the back off of the control panel. It should be folded up in there.
Feb 14, 2011 | Washing Machines
GE washer Model S3600DOWN will not turn off water. overflows WHY?
suspect water level control they call it a pressure switch
there is a quarter inch line that runs from tub to pressure switch that line can sometimes plug requiring line be removed from pressure switch and cleared
http://www.repairclinic.com/Washing-Machine-Top-Load-GE-Style-Appliance-Diagram
this web page shows a breakdown of commom top load ge washing machine level control is located in top panel
before opening top panel unplug washer from wall
if clearing line does not work level control will probably need to be replaced suggest take picture or draw out
where three wires are hooked before removing part or
change 1 wire at a time to avoid mixing up wiring
Dec 12, 2009 | GE Washing Machines
Trying to disable the dryer's loud buzzer
The wiring diagram is located in the slanted panel above the washer door
Jul 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Wires came unplugged from behind control knob
Below is the link to the wiring diagram to your dryer, it should help some. In addition what I can tell you is that most appliance components have initials next to the connections that indicate what color wire is supposed to be connected to them, this is where the diagram should help. In cases of things like switches, buzzers, thermostats, things that only have to do with circuits being open or closed they will not have an initial so therfor it doesn't matter what wire goes to what connection. Post again if you need more help. http://www.appliance-parts-warehouse.com/frigidaire-parts/Frigidaire-Dryer-Parts/Frigidaire-Parts-GLER331AS2/Frigidaire-Parts-50169.cfm
Jan 22, 2009 | Frigidaire GLER331A Electric Dryer
New install; where to hook up old wiring/plug to ASKO
There should be an installers/repair guide folded up behind the front panel. Check for that as it will show a wireing diagram. I won't be able to get any info until Jan 2. Let me know what you find.
Jan 01, 2009 | Asko D1976 Built-in Dishwasher
KUDP01IL Dishwasher heating element
element on allthe time sounds like a direct short of the wire leading to it, trace back the wire , it will lead directly to control board behind front panel. there should be a tech sheet behind the lower kick panel complete with wire diagram
Feb 27, 2008 | KitchenAid 24 in. KUDP01IL Stainless Steel...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
99 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
