Question about Remote Start System
I need a wiring diagram for a viper 5301 remote starter.
  • jhknittle Feb 06, 2010
    i have 7 seperate wiring plugs that go into the starter modual i dont understand what the h1 h2 h3 is
    also there is a on/off switch that im not sure about
  • 8,197 Answers
  1. red/white (-) 200ma trunk release output
  2. red (+) 12vdc constant input
  3. brown (-) horn honk ouput
  4. white/brown light flash isolation wire
  5. black (-) ground
  6. violet (+) door triger input
  7. blue factory horn input
  8. green (-) door triger input n/c or n/o
  9. black/white (-) dome light output
  10. white/blue(-) remote start/ tutbo timer activation input
  11. white parking light output
  12. orange(-) ground when armed output
H2
  1. light green/black factory alarm disarm output
  2. orange/black aux 4 output
  3. green/white factory alarm arm output
  4. violet/black aux 2 ouput
  5. white/black aux 3 output
  6. white/violet aux 1 output
  7. gray/black diesal wait to start
  8. empty
  9. violet/white tack input
  10. dark/blue status output
  11. pink/white flex relay control output
  12. orange axxesory output
  13. purple starter output
  14. pink ignition 1 output
  15. grey hood pin
  16. blue/white 2nd statis / rear defrogger output
  17. brown (+) brake shutdown input
  18. black/white neutral safty input
H3
  1. pink ignition 1 input/output
  2. red/white fused (30a) ignition 2 flex relay input 87
  3. orange accesory output
  4. violet starter output
  5. red fused (30a) igniton 1 input
  6. pink/white ignition 2 / flex relay output
  7. pink/black flex relay input 87a key side if required
  8. red/black fused (30a) accessory/ starter input
Posted on Feb 05, 2010
  • Jyackle5
    Jyackle5 Feb 05, 2010
    http://www.directeddealers.com/manuals/O...
    http://www.directeddealers.com then to manuals and it downloads a pdf file.
  • Jyackle5
    Jyackle5 Feb 06, 2010
    Here is the only other way layout the wires.
    WIRE COLOR POLARITY LOCATION
    Battery RED/WHITE (+) IGNITION SWITCH HARNESS
    Ignition 1 BLUE/GRAY (+) IGNITION SWITCH HARNESS
    Starter 1 YELLOW/BLUE (+) IGNITION SWITCH HARNESS
    All Door Trigger YELLOW (-) DRIVER'S KICK PANEL
    Alarm Disarm VIOLET/YELLOW (-) DRIVER'S KICK PANEL "BLK PLUG"
    Parking Lights BLUE/RED (+) LEFT OF STEERING COLUMN
    Convenience
    Headlights-Lo TAN/BLACK (+) AT LIGHT SWITCH
    Wipers-Lo BROWN/WHITE (+) AT STEERING COLUMN
    Remote Start
    Accessory 1 ORANGE/BLACK (+) IGNITION SWITCH HARNESS
    Tachometer GRAY/WHITE (-) AT COIL "BEHIND COOLANT BOTTLE"
    Brake Lights WHITE/TAN (+) AT BRAKE SWITCH OR DRIVER'S KICK
    Horn GRAY/ORANGE (-) AT STEERING COLUMN
    Modules
    WIRE LOCATION
    Please select another category
    Doorlocks/Windows
    Power Unlock PINK/VIOLET (+) POSITIVE TRIGGER
    Power Lock ORANGE/VIOLET (+) DRIVER'S KICK PANEL "BLK PLUG"
    LF Window Up LFLTBLUE
    RF Window Up RFBROWN/VIOLET, AT SWITCH
    LR Window Up LFWHITE
    RR Window Up RFVIOLET, AT SWITCH
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
I have a Viper 5301 LE 2 way remote starter system installed in a manual transmission. When I set my starter everything seems to be functioning normally. Once I get out of the car and hit the lock button...
It sounds like the turbo timer mode is active. In this procedure, the MTS remote starter is active, it's just that once set (after locking the vehicle) the vehicle will run the preset time(1,3,5 or 10 minutes) before shutting down. The MTS remote starter feature should still operate with the turbo timer mode.
Feb 08, 2011 | 5301 LE 2 Way Car Remote Starter System
Hooked up a Viper 5301 in a 2004 Nissan Murano. The problem I'm facing is that the unit is only programming when the vehicle is started and running, instead of programming after turning the ignition on...
It sounds like you have your ignition and starter wires reversed. The remote start programs when the ignition wire sees 12 volts and then loses the 12 volts. If you have the remote starts igniton wire on the trucks starter wire then that is why you can prgram it when you start it only... cause you get 12 volt only when the truck cranks and then loses the 12 volts once it is runnng. You may have the right colors from the remote starter correct but check to see if maybe from DEI they have the wires in the wrong positions.
Jan 20, 2011 | 5301 Responder LE 2Way Remote Start and...
I had a 5301 installed this week in a 07 Nissan Pathfinder. Everything seems to work fine except that when the vehicle starts the heater & fan does not come on. Did the installer miss a...
Sounds like the tech didnt hook up to the heater acc. wire located at the ignition cylinder. The color of the wire in the car is green\ yellow tracer.... Color of the wire from remotestart is orange. So find where the orange wire from the starter is and hook it up to the green\ yellow wire.
Jan 07, 2011 | 5301 Responder LE 2Way Remote Start and...
Viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Jan 15, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
Remote Start System  Logo
383 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
