Question about Maytag Washing Machines
I have a maytag washer model LA9800, washer filled but won't start to wash. Tub is in balance and I have tried other settings, but when I pull the knob out it won't start?
Washer_tech
  • 164 Answers
SOURCE: Maytag Washing Machine - water will not shut off and overflows tub
this could be either a bad pressure switch, located behind the control panel. it has a small usually black hose running down to the tub. more than likely since this is an older machine the hose has become worn in one spot and is leaking air. replace the hose and that shold do it. if not its the presasure switch.
Posted on Nov 29, 2007
SOURCE: Maytag lse7806ace
Had the same problem and was told that it was the water fill valve put a new one in lasted about 15 loads and back to the same fuse blowing
Posted on Jan 25, 2008
AT702
After removing the power (easist was to shut breaker off), then replaced fuse just inside upper front left cover area by way of 2 white screws on bottom front panel. Clips secure the top into the horizontial lid panel (which you will also have to remove later if fuse keeps blowing) That worked for a coupe weeks as long as the Cycle Selector dial was always pushed in when you opened/closed the washer lid. Then the the problem returned. Only way out was to partially remove the unit from the wall and remove the lid assembly, which was much easier than first thought. Pictures attached. Tools needed are Phillips screwdriver and Nut drivers to remove the horizontial lid/panel from above the washer tub, and below the timer panel/dryer. Didn't need to remove the angled cover below dryer as Washer Door lid assembly is wholly below. Just push the dryer toward the rear, then remove two larger nuts from top left and top right corners. No nuts at rear, just clips that slide in/out. This allows lid cover to be pulled straight out (I had to remove the overflow tube on front right of tub, and one semi-rusted nut-driven screw from the Hot/Cold filler plate which is at the rear of the lid cover. That will make it easier to manipulate the cover and release the 4-pin plastic connector shown in pictures at the left rear corner. Then the entire cover/lid slides out easily as you may have to push the dryer top back to ease it out. Then flip it over and replace the switch and slide the 4 wire connector back under the plastic trip. and reverse the un-install. 4-pin connector is flat-keyed on one side, but it is tight to get to. My OEM part even included a new fuse (19.95 + shipping) Unit is now working fine for last 2 weeks.b88b41c.jpg8de8e68.jpg798b349.jpg49eb6d1.jpg6f06d50.jpg48c84c4.jpg
Posted on Feb 01, 2008
  • 1003 Answers
SOURCE: Timer on maytag Atlantis
replace water inlet solenoid first if this doesnt work replace timer
Posted on Feb 02, 2008
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
The tub starts to fill then it shuts off wont complete wash cycle
Depending on the model, it could be a few things:
Fill level sensor
door switch
timer
control board
The model really matters, as Maytag has been making washers for 70 years. uploadserror please enter an image url (gif, jpg, png).
Dec 09, 2014 | Maytag Washing Machines
Maytag mah55flbwq not draining
Perfectly normal..
What you are actually hearing is a balance ring on the inner tub that has liquid inside to help keep washing loads balanced.
The balance ring is filled with a calcium chloride solution and baffles within the ring allow the fluid to disperse within the ring evenly
By rotating the spin basket you can hear the fluid dispersing within the baffles of the balance ring.
Thebalanceringisfilledwithacelciurnchloridesolutionandbaffles,withintheringallowthefluidtodispersewithinthe:ring,evenly
I also thought ours was not draining properly but discovered otherwise when I had to take the inner tub out for a bearing repair job..
Hope this puts your mind at rest..
Aug 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
Washer fills and then does nothing. turned to
this unit has two safeties
lid switch and out of balance switch
try pulling the tub forward
if you hjear a click it was cutting off on out of balance
then open the front and check that the flapper is actually closing the lkid swithc
\rear right corner
in the back
Oct 26, 2009 | Washing Machines
After setting washer it won't start
It sounds like the washer tub is off balanced. When it is, it will usually not start. Underneath the washer, there are 3 or 4 bolts or nuts, depending on your washer model, that hold the washer to these balance springs. make sure that the bolts or nuts are tight or secure. If this doesn't help, get on a website called Repairclinic.com. They usually will help with home repairs.
Thank You
Sep 12, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Neptune washer, model MAH5500BWW, not spinning up to speed
Open the lid. take one hand and push the tub back toward a back corner. Take your other hand and fill in the gap on the opposite corner. There should be a black round rubber strap going from the outside top of the tub to the cabinet. Once you find it check all four corners. I feel sure that you will find more than one broken. These help to keep the load balanced. It is very important that you change these as soon as possible due to after these break these machines are bad about the tub banging into the sides and cracking the outer tub. To replace the tub will run ( in my area) around $240 - $300. These straps are not hard to replace and don't cost very much. I would rate replacing them a 2 on a hardness scale from 1 to 10. 10 being the hardest.
Please rate this solution if helpful.
Aug 21, 2009 | Kenmore 42182 Top Load Washer
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer fills with water then stops
2 things make sure the washer is balanced. and make sure theres nothing was stuff in the bottom of the washer when you were moving
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
