Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John deer 6400 Shuttle shift will not engauge . I can here a relay activat in the fuse panel. If I hold the lever up the tractor will move forward and the same for reverse. But the lever will not stay there by its self.
    President:
  • 1,627 Answers
You have the old style reverser which has been replaced by one that beeps instead of kicking out.These are a known problem with Deere and that is why you can't buy them anymore.The fact that you can hold it in yourself indicates that the enable solenoid and the forward and reverse solenoid are ok and all safety switches are working.You need to replace the reversrer.
Posted on Feb 05, 2010
John Deere 760-A scraper will not move forward but it will back up.
It is almost like a 4620 powershift farm tractor trans. When reverse goes clutch packs are shot. Sorry about that. Be sure the shift linkage is moving full range top to bottom.
Nov 21, 2016 | John Deere Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
It is a 1993 john deere 6100. there are 3 forwards and 1 reverse on one gear stick- 1, 2 ,3, r and the other is a, b ,c ,d ,e. the 1, 2,3, r gear stick has becoe loose and u cannot select gears 2 and 3. I...
The shifters do run cables to the transmission but you likely only need to remove the panel from the right side that covers the shift rods and then you can tighten the 13mm nut that brings the linkage rods together,the nut is on the shift lever not the range lever,Let me know how you make out and if i am wrong also let me know and i will dig deeper.
Sep 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
May 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Forward/reverse lever not holding in position on John Deere 7210
Some come with a tension bushing underneath on linkage. Check that first
Jun 29, 2009 | John Deere 7200,7210 All W/o Cab Tractor...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
643 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
