Question about Maytag MBB1956GES Bottom Freezer Refrigerator
Smelly fridge my 4 year old fridge stopped working and smelt very fishy. After an hour it started again and is cold but the fishy smell is still there. Any solutions as to why? Thanks
  • Maytag Master
  • 3,740 Answers
Hi and welcome to Fixya. You mentioned the fridge stopped working for about an hour. That is about the time that it takes for a defrost cycle to complete. If something had somehow fallen onto the defrosting element it could actually partially cook during each defrost cycle. The element is covered by a glass tube and the tube gets hot during the defrost cycle.
You will not be able to see this without removing the access cover to the evaporator coils.
Cover is item 4 this link:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1317590&pkw_=basket&model_id=5170428&NewWindow=1
In back of the freezer on the very bottom there is a drain that you can not see due to the internal evaporator coil access cover of the freezer compartment. If there is debris in that drain everytime the unit defrosts it can also re-generate the odor.
Check item 3 of this drawing and make sure it is clear.
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1352363&pkw_=basket&model_id=5170428&NewWindow=1
My suspicions are in the first recomendation above more than the drain.
Also to rid the internal smell.... get a "box" of Arm and Hammer Baking Soda, tear the top at least half way back and place it in your Food section. It will over time rid your unit of unwanted odors.
Posted on Feb 06, 2010
Daewoo american fridge freezer bad smell
look up the fridge on line or check the manual how the freezer is build. some freezers have a small space under the bottom of what you see as the bottom, where liquids can be trapped and haunt you for ever if you done lift the bottom part up and get under it. good luck
Jan 27, 2018 | Daewoo Refrigerators
My fridge smells fishy. It is perfectly clean and i have not had fish in there.
Bacteria will cause the smell. Make sure it is cold and put a box of baking soda open inside the fridge. It will absorb the odors. They sell baking soda with a mesh side specifically for your fridge.
Jun 06, 2011 | Samsung RS2530BSH (25 cu ft) Side by Side...
Can't get the fishy smell out of fridge....used baster and put water with baking soda down drain under bottom freezer bin... took back off...cleaned compressor Hotpoint HSS25GFPA
I was watching tv the other day and they said if you want to get rid of awlful smelly smells use newspaper. Put newspaper in the frig and close the door. Let set for like two days and repeat. The newspaper will absorb the smell somehow because of the chemicals it has. It works great with pickle jars. no kidding.
Mar 23, 2010 | Hotpoint HSS25GFP Side by Side...
My propane fridge will not get cold
You have described an Ammonia refrigerator. The chemicals in the system are Ammonia, water, and hydrogen. In a crazy system of events, heating the bottom of the unit will cause the chemicals to seperate and then reunite in a complete cycle.
If you have never smelled a strong ammonia smell, then yes, the upside down thing will many times work.
The chemicals can become seperated in the wrong areas of the interior components.
Perform the upside down thing for 24 to 48 hours. Return to normal. Pause it for minimum of 4 yours and try again.
If the burner is working correctly, then you should see some results.
Oct 30, 2009 | Refrigerators
Smelt burning smell in the morning stopped cooling
I suspect the start relay burnt on the compressor. Now the compressor can not turn on. You need to repalce the relay.
Sep 04, 2009 | Kenmore 53542 / 53544 Side by Side...
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Apr 01, 2009 | Refrigerators
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Mike
Aug 14, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Smelly fridge`
Can you describe the smell or relate it to something common? Plastic, burned wires, fishy, rotted meat, etc. Is it only when you open the door or can you smell it outside too? Are the temps normal in the freezer and refer sections? When did the smell suddenly get noticed?
Nov 12, 2006 | Samsung RS2630SH Side by Side Refrigerator
Maytag MBB1956GES Bottom Freezer Refrigerator Logo
193 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
