Question about Amana ALG331RAW Gas Dryer
Amana Gas Dryer LGA50AW Ignites for only about a minute
Amana Gas Dryer LGA50AW Ignites and stays lit only about a minute continues to spin. Venting it is clear. No excess lint near ignitor or any parts for that matter. Replace dryer or repair?
  • 14 Answers
SOURCE: no heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Posted on Jul 25, 2008
  • 14 Answers
SOURCE: dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
  • 848 Answers
SOURCE: amana gas dryer
check the thermal fuse ........
Posted on Aug 28, 2008
  • 17 Answers
SOURCE: Gas dryer flame won't stay lit
Check for a blocked vent.
Posted on Mar 12, 2009
  • 12 Answers
SOURCE: I have an Amana gas(LP) dryer DLG330RAW that doesn't heat
Replace the two small round black solenoids located on the gas valvle. I just did it last week. They come in a set and only cost me $26.50. Easiest fix I've done. I was all set to go out and buy a new dryer.
Posted on Sep 24, 2009
Dryer wont relight
replace the 2 solenoid (gas coils) there are out very common
Aug 14, 2012 | Samsung Dryers
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
Dryer keeps tripping tstat or hi limit and cleaned all vent out
Could be a lint blockage and or a venting problem. Remove the connecting vent and clear any blockage found. The vent should be as short and straight as possible. No kinks.
Try a cycle with the vent OFF the dryer. Make sure there is plenty of fresh air circulation in the room.
If it dries OK the venting is the problem.
If it continues to short cycle you will have to replace the gas valve coils on top of the gas valve. They will be overheating and closing because they are weak.
Dec 22, 2009 | Estate TGDS840JQ Gas Dryer
I have an Amana gas(LP) dryer DLG330RAW that doesn't heat. When I turn on the dryer the ignitor glows red, and ignites a great flame for about 10 seconds, then I hear a click and the flame shuts down. A...
Sep 24, 2009 | Amana DLG330RAW Gas Dryer
Gas dryer heats for 10 minutes then heat goes off
it's doing what it's supposed to do. you should use a different setting.
Sep 07, 2009 | Dryers
The dryer ignites but the gas valve does'nt light
Check that the gas sensor is clear or any lint/dust/crud, etc. as that could be preventing the gas valve from opening up and allowing ignition. Typically all gas dryers have a safety feature that won't allow operation if the exhaust vent pipe has excessive lint and dust in it, as that is a fire hazard.
Look in your owner's manual to see the procedures for accessing the vent exhaust and follow your specific instructions. Usally there is an access panel/door at the bottom front of the dryer that will allow you to get inside the vent, etc. Inside that is a surface mounted sensor that does a couple of things; checks for proper air (venting) flow; no excessive dust/lint buildup; and that the ignitor coil has been "lit", etc.
If any of these doesn't occur, the gas valve will not open. Follow the monthly cleaning procedure/check to make certain that the dryer is safe to use and operate.
If all the above are OK, then it is likely that the sensor has failed and needs to be replaced. You can look at the searspartsdirect.com to find your particular model using their parts diagrams and illustrations of your dryer, etc.
Glad to assist!
Jul 13, 2009 | Amana NGD7200TW Gas Dryer
Dryer heating problem
Jul 04, 2008 | Amana ALG331RAW Gas Dryer
Amana alg643rb gas won't stay on
repl/ coils when bad does the same thing that it going on w/ your dryer
Feb 10, 2008 | Amana ALG643RB Gas Dryer
Gas dryer Model MDG9316AWW does not always ignite
First check the exhaust vent to the outside do you have a strong flow of air?
Is the lint passage free of lint? Are the blower vanes clear of lint?
A simple test for the sensors, bypassing the wires to the thermosensor and operating the dryer to test. If the heat now stays on the sensor is usually bad. Also if the flame backs up the safety thermo can kick out to protect against fires. Usually due to plugged lint somewhere.
Feb 04, 2008 | Dryers
Amana ALG331RAW Gas Dryer Logo
151 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
